    Webmanager: Where has the BIOS files upload and checksum check gone?
    webmanager where bios upload checksum check gone
    • RK.aus.S
      RK.aus.S last edited by
      Hi
      Earlier, I could check my BIOS files if there are missing or some with wrong checksum as well as the installed with the correct checksum.
      Now, I can't find this settings in the webmanager. Was it removed, or did I oversee something (new)?
      Kind regards
      Roman
        OyyoDams Staff @RK.aus.S last edited by
        @rk-aus-s Hi, now you can check bios directly from main interface of Recalbox.
        RK.aus.S 1 Reply Last reply Reply Quote 0
        • RK.aus.S
          RK.aus.S @OyyoDams last edited by
          @oyyodams
          Thanks.
          I could that do anyway in the past.
          Does this that the web manager BIOS management is removed?
          Regards
            @rk-aus-s yes it's deprecated
