    Power button not working with Odroid XU4
    button odroid xu4
    • A Former User
      A Former User last edited by
      Hi I'm using the Odroid XU4 with the latest version of Recalbox running on a clean install.
      The power button is correctly wired to the XU4 but doesn't work in Recalbox menu or in game. One strange thing though is that the button works in Kodi.
      Any ideas? Thanks!
      Zing olivierdroid92 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @Guest last edited by digitaLumberjack
        @deletedaccount I don't have an Odroid XU4 and I haven't seen any reports from other users.
        How are you sure the power button is correctly wired to the XU4?
        Did it work on previous versions?
        • olivierdroid92
          olivierdroid92 Global moderator @Guest last edited by digitaLumberjack
          @deletedaccount
          Hi
          I've tested 722 release on my XU4 and I was not able to reproduce the issue you reported.
          Would it be possible to provide step by step details?
