    Kodi & vpn
    MediaCenter & Dualboot
    kodi vpn
    20
    22
    16833
    • klen-ghost
      klen-ghost last edited by
      I was trying to set up a vpn inside kodi. But i seem to get stuck. Don't know what recalbox is based on. Is it openelec or raspbian (don't know what others are around). Maybe it is better if some one can write an how to for setting up a vpn in kodi (from recalbox). Thanks!
      sirus555 1 Reply Last reply Reply Quote 0
        Hello recalbox is a buildroot system. kodi is a light version i think. do you test this : https://seo-michael.co.uk/tutorial-how-to-install-vpn-for-openelec-on-kodi/ choose openvpn only
        • sirus555
          sirus555 @klen-ghost last edited by
          @klen-ghost Hi. Just out of curiousity, did you get this working? I have had a similar issue with my build (non-Recal os).
          The way I have worked around it was to install openvpn on Raspian, then OpenVpn on Kodi. The issue that causes is that my key and controllers are stuck and would need to unplug and replug to get them working again.
          Steps I have done:
          in Console - apt-get install openvpn
          then kodi install openvpn and add settings
          • Nicole Byer
            Nicole Byer last edited by
            Look at this guide https://support.purevpn.com/openelec-how-to-configure-openvpn
            Easy to configure VPN on Kodi in 5 simple steps.
            • willieaames
              willieaames last edited by
              This guide is pretty much helpful if you want to setup vpn on kodi: https://www.bestvpnprovider.com/kodi-vpn/
              • venom
                venom last edited by
                I have tried installing VPN Manager for openvpn and unfortunately does not work.
                Tried shelling out and did not recognise -apt anyway.
                I have asked the writer of vpn manager for openvpn to see if there is a workaround or not. I love recalbox compared to other images.
                E.g Reys 128gb image, if you dont have a controller plugged in it wont load up. I mainly have mine unplugged and use cec with tv remote for kodi. I add subtitles to recalbox kodi version and other addons with no issues at all. Just need to get vpn working, as I have a paid service and may as well use it for this as well. Any help would be appreciated .
                  No vpn nor torrent clients, and don't expect we add one of them.
                  • ZachGold
                    ZachGold last edited by
                    No out-of-the-box solution seems to be available and i think you won't find it anytime soon. but you can always check out stuff over kodi's forum and reddit because you have a better chance of getting answered there. i personally made ivacy vpn work on OE Kodi but i haven't tried it on recalbox. most of the tuts out there seem to be on Raspian though. happy googling.
                    • venom
                      venom last edited by venom
                      Found out that recalbox has no openvpn executable so wont work so will try . http://www.matthuisman.nz/2015/11/recalbox-kodi-dual-boot-images.html
                      Also see here
                      https://forum.libreelec.tv/thread-5032-page-8.html
                      • amyacker
                        amyacker last edited by
                        How you solve the issue with booting into external kodi vpn in version1.3+?
                          Substring @amyacker last edited by
                          I'll keep a moderating eye on this topic ...
                          • Neil_Hines
                            Neil_Hines last edited by
                            Setting up a VPN for Kodi is a pretty technical procedure. I myself got it installed from the place where I purchased it. Moreover, OpenElec is a part of Linux, so in my humble guess, if you can find Kodi VPN setting for Linux, I think it would be quite similar to it.
                            • jeanericblass
                              jeanericblass last edited by
                              the important question is that why i should use vpn for kodi? so my dear there are many addons which are still block on kodi due to regional restrictions and this restrictions can be unblock only with kodi. However here is a detail resource that i love a lot for the best kodi guide.
                              laurenmartinln10 1 Reply Last reply Reply Quote 0
                              • laurenmartinln10
                                laurenmartinln10 @jeanericblass last edited by laurenmartinln10
                                @jeanericblass said in Kodi & vpn:
                                In the whole of this comment you missed to mention the source of the article that you actually love so here the article that actually i love and i hope you will also like this: www.vpnranks_com/kodi-vpn/
                                • vpn4kodi.com
                                  vpn4kodi.com last edited by
                                  what i did was i made a load of step by step guides if you get a chance have a look www.vpn4kodi.com
                                  • psiphon3app
                                    psiphon3app last edited by
                                    try psiphon 3 for kodi . it will work fine on any device. download form psiphon3download.com
                                    • wilsondrake
                                      wilsondrake last edited by
                                      I highly doubt these freaking VPNs because of their policies and log keeping. But the only thing which makes me use a VPN is my favorite content on KODI, obviously cannot really compromise that. So I make sure I use the best vpn for kodi, to get flawless streaming and minimal log keeping.
                                      • rilynnevania
                                        rilynnevania last edited by
                                        1. First download WinSCP & OpenVPN Files
                                        2. Now create a new text file pass.txt on your dekstop and insert VPN Username and password. Username in first line and password in second line.
                                        3. Now open downloaded OVPN File and edit the following lines.
                                          tls-auth to tls-auth /storage/.config/Wdc.key 1
                                          ca ca.crt to ca /storage/.config/ca.crt
                                          auth-user-pass to auth-user-pass /storage/.config/pass.txt
                                        4.Your OVPN files should look like this, save it.
                                        Regards
                                        bestvpnforkodi.co
                                        • markhascole
                                          markhascole last edited by
                                          This guide will definitely help you: http://bit.ly/2Eqs08s
                                          • niga higa
                                            niga higa last edited by
                                            click on the link to know how to install Dolby atmos apk free
                                            101.4k
