    Still Wifi Issues with 7.2.1
    still wifi 7.2.1
    6
    15
    3217
    • retroplayer88
      retroplayer88 last edited by retroplayer88
      Hello, I have a Intel Wireless-AC 8265 in my Intel NUC. With Version 7.1 wifi worked fine. With Version 7.2 wifi stopped working. With Version 7.2.1 wifi works only if I connect with WPS to my router. After a Restart no Connection. I have to reconnect everytime with WPS. Switching Wifi ON/OFF in Menu does not make a change. Really strange 😞 Hope this is getting fixed in next release.
      EDIT: And yes I have made a fresh install of recalbox 👍
      Zing skrapps 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @retroplayer88 last edited by
        @retroplayer88 How are you turning off Recalbox?
        Have you ever tried to manually add, with Recalbox turned off, the wifi name and password to the recalbox.conf file?
        • retroplayer88
          Thanks for the response.
          @zing said in Still Wifi Issues with 7.2.1:
          Like I always do. Menu -->Shutdown Recalbox
          My Wifi SSID and key are correct in the recalbox.conf file. Also tried Region from JP to DE, no success. As I said 7.1 was running fine with my setup. I did not change anything, only update to 7.2 and then 7.2.1.
            @retroplayer88 Have you ever tried a factory reset, available through the advanced settings menu? This will not affect your personal files, but it will erase all custom settings.
            • retroplayer88
              Yes, always the same behavior. Luckily my router is not too far away from my Intel-NUC (ModelNUC7i7BNH) so I can use it with Ethernet Cable. Hop you guys can fix that in the next Update. I think there must be a difference between 7.1 and 7.2.1 in terms of the Driver for my Intel Wireless-AC 8265 Chip.
              If you got a Beta that I can test send me a Link 👍
                @retroplayer88 @Emma I'm not a developer, I'm not even a team member, I'm "just" a moderator, I help keep the forum organized and I try to help users where possible before there's a need for developer intervention.
                I'll not "release" any betas, and it's not often that a fix is readily available.
                I recommend that one of you open an issue describing the problem and referencing this topic (and that the other confirm the issue):
                https://gitlab.com/recalbox/recalbox/-/issues
                retroplayer88 1 Reply Last reply Reply Quote 0
                • retroplayer88
                  retroplayer88 @Zing last edited by
                  @zing
                  Ok thanks, I will report this there.
                  • skrapps
                    skrapps @retroplayer88 last edited by
                    @retroplayer88 hey, im not sure if recalbox works the same as retropie inside, but i was having wifi issues on the new retropie update, and it turns out i had to downgrade the drivers. maybe its possible the drivers need to be downgraded as well on recalbox?
                    • xtreemsurf
                      xtreemsurf last edited by
                      I just updated to 7.2.2 and it corrected my WiFi issues! 🙂
                      • retroplayer88
                        retroplayer88 @xtreemsurf last edited by
                        @xtreemsurf
                        You're lucky. Also updated to 7.2.2 but still the same issue.
                        Zing Dralctig 2 Replies Last reply Reply Quote 0
                          @retroplayer88 Can you test with a totally clean installation, without any modification?
                          • retroplayer88
                            I will do but I have figured out that it has to do something with my Router (Fritz Box 7590). I created a Wifi Hotspot with my Android Smartphone and Recalbox connected successfully with my Smartphone! The strange thing is I didn't change nothing in my Router. All the settings are same as they were with Recalbox 7.1.1 when my Wifi was working.
                            retroplayer88 Zing 2 Replies Last reply Reply Quote 0
                            • retroplayer88
                              retroplayer88 @retroplayer88 last edited by
                              @retroplayer88
                              Tried clean install but same problem. With Batocera it´s working! 😐
                                @retroplayer88 With cable, does it work?
                                Try changing the encryption or password on the modem, as a test, it's a good idea to make the network name and password as simple as possible, with no special characters.
                                • Dralctig
                                  Dralctig @retroplayer88 last edited by
                                  @retroplayer88 said in Still Wifi Issues with 7.2.1:
                                  @xtreemsurf
                                  I got this problem when I update to 7.2.2 no fix yet
