    Some games not working since latest release
    bubble bobble controller free start button
    • Blythy79
      Blythy79 last edited by
      Hi, I have the recalbox and completed the new release recently
      since then, I have a couple of games that go to their home page, but no buttons that I press work - the games are Bubble Bobble Featuring Rainbow Island and also Bomberman
      both games worked perfectly before the release......the controllers are not the issue as they work fine on other games
      Any ideas? please note I am not technical at all
      thanks in advance
        Zing Global moderator Translator @Blythy79 last edited by
        @blythy79 You need to check the ROMSET of your ROMS: on all Arcade consoles, it is necessary that the ROM version corresponds to the core version, for example, the MAME2003 core will be used with MAME2003 roms, you can even work with MAME2010 ROMs and vice versa, but not in the right way.
        The required ROMSETs are described here:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/generalite/les-roms-et-les-isos/les-romset-pour-recalbox
        You can convert the ROMSET of your ROMS using tools like Romulus or ClrmamePro (most popular):
        • https://recalbox.gitbook.io/documentation/tutorials/utility/rom-management/romulus-tutorial
        • https://recalbox.gitbook.io/documentation/tutorials/utility/rom-management/clrmamepro-tutorial
          Some users prefer to download complete ROMS packages from the internet, but I can't help you in this case because these files are protected by copyright, so if you do it this way, you will have to do it yourself.
        In addition, you need to verify that you have all the necessary BIOS, in the EmulationStation menu there is a BIOS checker, use it.
        • Blythy79
          Thank you very much, that makes sense! I will check that all over later and try to fix it
          Thank you very much
          • barbudreadmon
            barbudreadmon @Zing last edited by barbudreadmon
            @zing said in Some games not working since latest release:
            I'm not sure which Bomberman the OP is talking about, but "Bubble Bobble Featuring Rainbow Island" is definitely a psx game.
            @Blythy79 If the Bomberman is also PSX, then my guess would be improper device settings, i already mentioned it in other topics : you need a proper "device type" value set in Quick menu > Controls > Port X Controls, and you need to set the proper multitap setting in Quick menu > Options depending on the game, meaning disabling multitap for games not compatible with it, or enabling it on the right port for compatible games.
            Libretro developper :
            • FBAlpha FBNeo (Arcade)
            • Kronos (Sega Saturn/ST-V)
            • YabaSanshiro (Sega Saturn)
