    upgraded to 7.2.1 - psx
    upgraded 7.2.1
    • ianmcc1
      ianmcc1 last edited by ianmcc1
      so i upgraded to the new stable version, go to look at my psx games and all the tracks now show up instead of of a single file, what did i break? i tried uploading an image but its throwing me an error. basically i have like 30 tracks of Alien Trilogy instead of one. All games are displaying like this.
        Zing Global moderator Translator @ianmcc1 last edited by
        @ianmcc1 Have you tried hiding the files?
        Try with external software like Skraper or ARRM:
        • Skraper: https://www.youtube.com/watch?v=G388Gc6kkRs&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=22&ab_channel=Recalbox
        • ARRM: https://forum.recalbox.com/topic/11850/arrm-another-recalbox-roms-manager
        Another possibility is for you to do a factory reset (I don't know the right term in English), it is a new function of version 7.2 (and it has already helped many users).
        The factory reset will erase all your customized settings, but will not delete any personal files (ROMS / BIOS / SAVES).
        If you have another SD card and do not want to lose your customized settings for testing, do a clean install of the latest version and test.
        ianmcc1 1 Reply Last reply Reply Quote 0
        • ianmcc1
          ianmcc1 @Zing last edited by
          @zing i will check out the ARRM software, i formatted my sd card, fresh install and updated and it was still displaying all the track information, i hid file contents and no change. ill try the factory reset before i start messing with external software like ARRM.
            @ianmcc1 There is yet another option: converting your games to another format, such as .pbp, takes up less storage space, do a little research and test if you are interested.
            • ianmcc1
              @zing i just wanted to follow up on this post. i did a clean install and the files in psx show up as they should, its only when i run skraper for images do the tracks all show up. so ill have to look into that and see what i broke in skraper. thanks for your help zing.
