    8bitdo N30 pro not working with 7.2.1
    n30 7.2.1
    • jestrogar
      jestrogar last edited by jestrogar
      Since version 7.2 and also with 7.2.1, the 8bitsdo N30 pro pad controller does not work properly. It worked in 7.1.1.
      You can pair it (START+B) but then when you try to play arcade games, it disconnects and you have to connect it again. Then the select button does not work properly because when you use it to insert a coin it changes the shadders. is recalbox team planning to solve this?. Tried Start+X or START+Y and they do not work properly
        Zing Global moderator Translator @jestrogar last edited by Zing
        @jestrogar Please use the search tool before posting:
        https://forum.recalbox.com/topic/23878/7-2-can-no-longer-pair-8bitdo-sn30-pro-controllers
        And please, don't SPAM:
        https://forum.recalbox.com/topic/24205/recalbox-v7-2-1-commentaires-issues/25
        • Locked by  Zing Zing
