    [RESOLVED]Icefilms addon stopped working in 3.2.8
    addon stopped 3.2.8
    5251
    • james-lord
      james-lord last edited by
      Was working fine in Kodi in 3.2.7, now no longer, error comes up saying "An error has occured communicating with Icefilms Check your internet connection and the Icefilms site" Followed by a script failure popup Net connections seems fine (Youtube works) and https://ipv6.icefilms.info is up (and in the config of the addon) but it's not working anymore Anyone else got it working?
      • digitaLumberjack
        Weird as there are no differences on kodi between 3.2.7 and 3.2.8 except PVR support. Can you get the content of /root/.kodi/temp/kodi.log ?
        • james-lord
          this seems to be the relevant bit:
          01:26:35 T:1746068496  NOTICE: -->Python Interpreter Initialized<--
          01:26:36 T:1746068496  NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
          01:26:36 T:1746068496  NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.8.3
          01:26:36 T:1746068496  NOTICE: Icefilms: ----------------Icefilms Addon Param Info----------------------
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Version: 1.8.3
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Mode: 11
          01:26:36 T:1746068496  NOTICE: Icefilms: --- URL: https://ipv6.icefilms.info/tv/popular/1
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Video Type:
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Name: Popular
          01:26:36 T:1746068496  NOTICE: Icefilms: --- IMDB:
          01:26:36 T:1746068496  NOTICE: Icefilms: --- TMDB:
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Season:
          01:26:36 T:1746068496  NOTICE: Icefilms: --- Episode:
          01:26:36 T:1746068496  NOTICE: Icefilms: --- MyHandle: 30
          01:26:36 T:1746068496  NOTICE: Icefilms: ---------------------------------------------------------------
          01:26:36 T:1746068496  NOTICE: Icefilms: Loading sqlite3 as DB engine version: 3.8.8.3
          01:26:36 T:1746068496  NOTICE: Icefilms: GetUrl: https://ipv6.icefilms.info/tv/popular/1
          01:26:36 T:1746068496  NOTICE: Icefilms: params: None
          01:26:36 T:1746068496  NOTICE: Icefilms: referrer: 'http://www.icefilms.info'
          01:26:36 T:1746068496  NOTICE: Icefilms: cookie: False
          01:26:36 T:1746068496  NOTICE: Icefilms: save_cookie: False
          01:26:36 T:1746068496   ERROR: Icefilms: ****** ERROR: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:581)>
          01:26:36 T:1746068496  NOTICE: Icefilms: An error has occured communicating with Icefilms  Check your internet connection and the Icefilms site.
          01:26:37 T:1642591248  NOTICE: Thread BackgroundLoader start, auto delete: false
          01:26:51 T:1746068496  NOTICE: Previous line repeats 2 times.
          01:26:51 T:1746068496  NOTICE: metahandler: Looking up TMDB config cache values
          01:26:51 T:1746068496  NOTICE: metahandler: Cache still valid, setting values
          01:26:52 T:1746068496  NOTICE: metahandler: No SQLite rows requiring update
          01:26:52 T:1746068496  NOTICE: metahandler: Looking up in local cache for addon id: plugin.video.icefilms
          01:26:52 T:1746068496   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                       - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                                      Error Type: <type 'exceptions.AttributeError'>
                                                      Error Contents: 'NoneType' object has no attribute 'group'
                                                      Traceback (most recent call last):
                                                        File "/root/.kodi/addons/plugin.video.icefilms/default.py", line 3334, in <module>
                                                          TVINDEX(url)
                                                        File "/root/.kodi/addons/plugin.video.icefilms/default.py", line 1260, in TVINDEX
                                                          ADD_ITEM(metaget,meta_installed,scrape.group(1),scrape.group(2),scrape.group(3),12, totalitems=1)
                                                      AttributeError: 'NoneType' object has no attribute 'group'
                                                      -->End of Python script error report<--
          01:26:52 T:1951535968   ERROR: GetDirectory - Error getting plugin://plugin.video.icefilms/?mode=11&name=Popular&url=https%3a%2f%2fipv6.icefilms.info%2ftv%2fpopular%2f1
          01:26:52 T:1951535968   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.icefilms/?mode=11&name=Popular&url=https%3a%2f%2fipv6.icefilms.info%2ftv%2fpopular%2f1) failed
          01:26:52 T:1746068496  NOTICE: Thread BackgroundLoader start, auto delete: false
          Is that enough, or do you need to see more?
          • digitaLumberjack
            Ok, the same ssl issue as https://github.com/digitalLumberjack/recalbox-os/issues/139
            • james-lord
              Confirming the OpenSSL fix has Fixed this in 3.2.9 wonderful work! thank you 🙂
              • digitaLumberjack
                Cool !
                • narendra
                  narendra last edited by
                  yes now its working on latest version for get latest version try this method Install icefilms On Kodi krypton article
                    Substring @narendra last edited by
                    @narendra your mom never taught you not to necro 2 years-old topics ?
                    • bestofkodiaddons
                      bestofkodiaddons Banned last edited by
                      This post is deleted!
