    Amiga emulator. Sound is not syncronized on games
    Emulator Arcade/PC/Console
    amiga emulator sound syncronized
    • FranAvalon
      FranAvalon last edited by
      Hi,
      First, thanks for all work done on recalbox.
      I have a raspberry 400 and I was testing the Amiga emulator included on recalbox 7.2 and on the new beta 7.2.1. I found that the sound isn't syncronized on games. I mean, you hear the sound a bit later after the action you have done (over 1 sec later or so). I've tried to modify emulator config but not luck here.
      However, I've tested FS-UAE running on Ubuntu 21.04 on the same machine and it works perfectly.
      I don't know if someone has the same issue as me or if I am doing sth wrong.
      Can someone tell me his/her experience here?
      Thanks in advanced
        Zing Global moderator Translator @FranAvalon last edited by
        @franavalon
        the new beta 7.2.1
        I recommend that you post your beta issues on the beta topic:
        https://forum.recalbox.com/topic/24142/recalbox-7-2-1-beta3-public-release
        • FranAvalon
          I will do that,
          I've posted here because I'd found it on 7.2 version. I've mentioned the beta one because the issue is there too.
          Thanks
          flomartin 1 Reply Last reply Reply Quote 0
          • flomartin
            flomartin @FranAvalon last edited by
            @franavalon
            On my Rpi4 with 7.2 I don't have this issue.
            Are you using PUAE or Amiberry?
            Have you tried to modify the settings ?
            There are plenty of options that could help.
            PUAE works just fine for me.
            All my games are in whdload format, lha compressed.
            What about yours?
            • FranAvalon
              Hi, thx for your answer.
              I am using Amyberry emulator and I've changed settings on sound emulation, reducing bit rate to 22000 for example, or reducing a bit the buffer value (too low give you a weird sound) but as I said in my post I didn't get good results with that.
              My games for Amiga are disk images (ADF format).
              When I try PUAE, some games have problems to load and give me the "Guru Meditation" error, games which load without problems on Amyberry or FS-UAE emulators.
              Could you tell me your Amiga emulator configuration? So I can try
              Thanks in advance
