    rb 7.2 and edimax dongle Edimax EW-7811UN Nano on rpi2b
    7.2 dongle edimax ew-7811un nano
    1139
    • pommer452
      pommer452 last edited by pommer452
      hello,
      my config : rp2b with Edimax EW-7811UN Nano , external hdd , and bluethooth csl dongle
      i upgraded from 7.1 to 7.2 . (eveything was ok on 7.1)
      Since the upgrade , i'm stuck on the 4 phantoms screens. not able to do anything (my joystick is paired and i have leds on the bt + wifi).
      If i remove the edimax wifi, RB7.2 works ok
      i tried to start without the dongle, then inside rb7.2 put the dongle + wifi parameter => ok . When i reboot => stuck.
      i also tried from a fresh pi3 imager install => same issue with the wifi dongle plugged.
      Can you help to debug, and/or let me know what files to check ?
      thank you.
        Scavy Global moderator @pommer452 last edited by
        @pommer452 A beta tester has just tested with a tp link wifi module, using v7.2, es launches. Can you try another wifi module ?
        • pommer452
          Hello Scavy,
          i tried with a bewan wifi usb 315n, and it works. I'm getting into the recalbox menu.
          Problems could be linked to edimax driver ?
          tks
            @pommer452 i guess there's something wrong between your edimax module and rcb... what ? couldn't say ^^
            • pommer452
              at least i have a solution with the bewan stick. But to continue investigations, could you tell me where i could find the logs when emulstation is loading , so i can try more to understand why it hangs ? tks
              davidb2111 1 Reply Last reply Reply Quote 0
              • davidb2111
                davidb2111 Staff @pommer452 last edited by
                Hi @pommer452
                Logs can be found on the share partition under system/logs directory.
