    Kodi + netflix = black screen
    MediaCenter & Dualboot
    kodi netflix
    2297
    • RB2021
      RB2021 last edited by
      Hello !
      I installed Recalbox 7.2 on a RB pi 4. Everything is ok. I install Netflix add-on.
      I can login, navigate, see my profile and details. I installed Widvine as asked by Kodi. But now, when I try to launch a video from netflix, the screen is doing as it was going to put the movie, then it goes back to the list of episodes...
      Did I miss something ?
      Thanks fo ryour help !
      Recalbox 7.2 + Raspberry PI4 8Go + SD card 64Go
      • RB2021
        I succeed in installing netflix on independant Kodi (other sd card). It worked perfectly.
        So i did the same with RB 7.2.
        I have now the video launching but with black screen. (I see the name the subtitle, I see, the name of the video put above the video itself by netflix, but no image).
        I saw an other topic saying that peole wre having problems to read videos. Is that the same problem ?
        thanks for the help.
        RB2021 1 Reply Last reply Reply Quote 0
        • RB2021
          RB2021 @RB2021 last edited by
          @RB2021
          see :
          Solution here
          Solved !
          • floraolivia6
            floraolivia6 Banned last edited by
            This post is deleted!
            Zeke 1 Reply Last reply Reply Quote 0
            • Zeke
              Zeke @floraolivia6 last edited by
              Hello, I also had the problem on 7.2 but with all video under Kodi. I havn't tested but it seems to me that the problem is corrected under 7.2.1.
              PC x64 MSI X399 SLI Plus
              AMD Threadripper 1900X
              64GB Corsair Vengeance 3200Mhz
              EVGA GeForce GTX 1060 6GB
              Recalbox sur Western Digital Blue SSD 500Go M.2 (boitier USB-C 3.1 Gen.2)
              φ(k) ∝ At
              • Shaynesherman
                Shaynesherman last edited by
                Do you have multiple profiles in your Netflix account? When I used the Netflix addon about a year ago I always had issues with it syncing those because the addon changed or lost the 'default' profile every now and then. But this guide can help me with the issue.
