    Odroid XU4 | 7.2 upgrade | Blank screen | No output
    7.2 blank odroid output upgrade
    8007
    • f00f00t
      f00f00t last edited by f00f00t
      After upgrading to to 7.2 on the Odroid XU4, there's no output to the monitor via HDMI, I have web GUI and SSH access but I cannot get any image outpt to the screen.
      I went back to 7.1.1 and screen output is back.
      Please let me know what I can do to help diagnose the problem,
      I also have teh support log data if you need me to upload it as well.
      https://file.io/F6ca1VgLCmLm
      Thank you
      f00f00t 1 Reply Last reply Reply Quote 0
      • f00f00t
        f00f00t @f00f00t last edited by
        I upgraded again just to make sure and the there's no ouput
        here's ythe support log.
        https://transfer.sh/1lJkT/recalbox-support-507e3721-dcba-248a-c279-6fae310fee53.tar.gz
        • davidb2111
          davidb2111 Staff last edited by
          Hi @f00f00t
          Is it a fanless version (xu4q) or not?
          David
          • davidb2111
            Also, did you modify the file boot.ini on the RECALBOX partition?
            by default, the env videoconfig line is:
            setenv videoconfig "video=HDMI-A-1:1920x1080@60"
            is enabled. Does this match your screen/tv resolution?
            • f00f00t
              f00f00t @davidb2111 last edited by f00f00t
              @davidb2111 Hi there!
              I have the xU4 with the heatsink and Fan; the boot.ini file, I edited to this setting
              I hashed out that line you have and the below is configured
              #setenv videoconfig "video=HDMI-A-1:1920x1080@60"
              setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080.bin"
              Thank you
              • davidb2111
                in fact, that line is optional.
                Can you try to comment all setenv videoconfig lines ?
                • davidb2111
                  In the logs you provide, there is [ 3.147092] [drm] Cannot find any crtc or sizes.
                  I compared with my own XU4 which reports it had found a frame buffer device.
                  There is definitely something hardware related. Did you tried to change the HDMI cable maybe?
                  • f00f00t
                    @davidb2111 Hi there,
                    So I went to the supermarket and bought two new HDMI cables and below is the updates/findings
                    7.1.1 - support log
                    https://transfer.sh/XueTC/recalbox-support-ba4a9e52-aaa1-2854-2b91-0758f2c8c3cc.tar.gz
                    • New Belkin 4K HDMI Cable (Model 4320F3 - 7100-00567 Rev A00)
                    • Working with no issue
                    • Set resolution to 720x480
                    7.2 - support log
                    After offline upgrade
                    https://transfer.sh/K6D3A/recalbox-support-97776b2d-3f33-2d18-173c-79d86d43d92d.tar.gz
                    • Same new Belkin 4K HDMI Cable (Model 4320F3 - 7100-00567 Rev A00)
                    • No screen
                    • Set resolution to 640x480, 720x480, 720x576, 1920x1080
                      setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x576.bin"
                      setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x480.bin"
                      setenv videoconfig "drm_kms_helper.edid_firmware=edid/640x480.bin"
                    • Tried a second HDMI cable
                    • Tried on Samsung 55" TV
                    • Tried on Scer 20" monitor with new HDMI cable
                    • Still no image on all screens I tried.
                      BUT
                    • Can access recalbox via network (using web browser to access recalbox manager)
                    Proof of setup (just a testing monitor)
                    [img]https://i.imgur.com/Y5umnch.jpg[/img]
                    Proof of boot up working on 7.1.1
                    [img]https://i.imgur.com/naEdCVr.jpg[/img]
                    Proof of update
                    [img]https://i.imgur.com/MyKKhb0.jpg[/img]
                    Proof of update running
                    [img]https://i.imgur.com/tY05tPf.jpg[/img]
                    Failure when on 7.2
                    [img]https://i.imgur.com/BwJNSKR.jpg[/img]
                    • davidb2111
                      Okay, got it!
                      I've tested the same boot.ini conf as you:
                      setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x800.bin"
                      after reboot, no signal sent to the screen, just like you.
                      Could you try commenting the setenv videoconfig line and enabling this, around line 21:
                      Seems like setting the edid does not work, only setting drm kms mode.
                      f00f00t 2 Replies Last reply Reply Quote 0
                      • f00f00t
                        @davidb2111 Standby, I will test now and update you.
                        • f00f00t
                          sorry I took too much time to reply here's my testing
                          • New sandisk 64GB SD Card
                          • Flashed recalbox 7.2 (No upgrade, just 7.2 flash/install directly)
                          • Using 20" Acer 1920x1080p 60Hz Monitor
                          • Set each resolution tested with Log
                          • SSH access works
                          • HTTP(s) access works
                          • No image on screen, nothing displayed
                            https://transfer.sh/kGHcM/recalbox-support-cb95ef47-1c57-d2d7-2cc8-b59ea907511c.tar.gz
                          • SSH access works
                            https://transfer.sh/TJVFT/recalbox-support-ac24381f-1111-8a8a-5dd7-5b3f5737be9a.tar.gz
                          setenv videoconfig "video=HDMI-A-1:1920x1080@50"
                          • SSH access works
                            https://transfer.sh/10fRfR/recalbox-support-b11f7322-78ae-f044-e4e3-66c5ca683328.tar.gz
                          setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080_50hz.bin"
                          • SSH access works
                            https://transfer.sh/TWIux/recalbox-support-bd374e79-da9e-042d-b3a3-de5c928fc23b.tar.gz
                          setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"
                          • SSH access works
                            https://transfer.sh/8LBdu/recalbox-support-72515c92-f911-2933-28a8-4d9f735900db.tar.gz
                          setenv videoconfig "video=HDMI-A-1:1280x720@60"
                          • SSH access works
                            https://transfer.sh/SXNCU/recalbox-support-1be7e3e6-d023-059b-dde7-e37efc280ed5.tar.gz
                          setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x720.bin"
                          • SSH access works
                            https://transfer.sh/CL5Gk/recalbox-support-75af2efb-d81b-cd53-78d9-257bc9f117c1.tar.gz
                          setenv videoconfig "drm_kms_helper.edid_firmware=edid/1024x768.bin"
                          • SSH access works
                            https://transfer.sh/10k8RV/recalbox-support-a2129376-9f98-6c3e-ac13-d7d41b7db75f.tar.gz
                          • SSH access works
                            https://transfer.sh/V9jvM/recalbox-support-915f5e68-1a37-b597-543a-dcab2c14ad42.tar.gz
                          • SSH access works
                            https://transfer.sh/jGwkG/recalbox-support-e1b6d979-b576-ab0e-2e4b-f9166456fed4.tar.gz
                          • SSH access works
                            https://transfer.sh/c3Llo/recalbox-support-4641427e-ef07-57cc-251a-ba0c24be052d.tar.gz
                          • davidb2111
                            davidb2111 Staff last edited by davidb2111
                            Hi again!
                            Could you post your boot.ini ?
                            • davidb2111
                              Your issue looks similar to this one reported here https://forum.odroid.com/viewtopic.php?f=95&t=15467
                              for testing, could you try uncomment setenv videoconfig "video=HDMI-A-1:1920x1080@60" and comment all other videoconfig lines.
                              Then unplug your monitor, reboot, and plug the monitor after the XU4 has completely booted.
                              • f00f00t
                                @davidb2111 Ok,
                                https://www.mediafire.com/file/rx3eq90mfkpcgqx/boot.ini/file
                                Boot.ini in plain text
                                ODROIDXU-UBOOT-CONFIG
                                U-Boot Parameters (DO NOT MODIFY)
                                setenv version 4.14
                                setenv zimage boot/linux
                                setenv fdtbin boot/exynos5422-odroidxu4.dtb
                                setenv uInitrd boot/uInitrd
                                --- Screen Configuration for HDMI ---
                                Uncomment only ONE line! Leave all commented for automatic selection.
                                Uncomment only the setenv line!
                                ODROID-VU forced resolution
                                setenv videoconfig "video=HDMI-A-1:1280x800@60"
                                ODROID-VU forced EDID
                                1920x1080 (1080P) with monitor provided EDID information. (1080p-edid)
                                #############################setenv videoconfig "video=HDMI-A-1:1920x1080@60"
                                1920x1080 (1080P) without monitor data using generic information (1080p-noedid)
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080.bin"
                                1920x1080 50hz (1080P) with monitor provided EDID information. (1080p 50hz-edid)
                                #############################setenv videoconfig "video=HDMI-A-1:1920x1080@50"
                                1920x1080 50hz (1080P) without monitor data using generic information (1080p 50hz-noedid)
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080_50hz.bin"
                                1440x900 with monitor provided EDID information.
                                setenv videoconfig "video=HDMI-A-1:1440x900@60"
                                1440x900 without monitor data using generic information
                                setenv videoconfig "drm_kms_helper.edid_firmware=edid/1440x900.bin"
                                1280x1024 without monitor data using generic information
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"
                                1280x720 (720P) with monitor provided EDID information. (720p-edid)
                                #############################setenv videoconfig "video=HDMI-A-1:1280x720@60"
                                1280x720 (720P) without monitor data using generic information (720p-noedid)
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x720.bin"
                                1024x768 without monitor data using generic information
                                1024x600 without monitor data using generic information (ODROID VU7+)
                                setenv videoconfig "drm_kms_helper.edid_firmware=edid/1024x600.bin"
                                800x600 without monitor data using generic information
                                setenv videoconfig "drm_kms_helper.edid_firmware=edid/800x600.bin"
                                800x480 without monitor data using generic information (ODROID 7")
                                setenv videoconfig "drm_kms_helper.edid_firmware=edid/800x480.bin"
                                720x576 without monitor data using generic information
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x576.bin"
                                720x480 without monitor data using generic information
                                #############################setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x480.bin"
                                640x480 without monitor data using generic information
                                --- HDMI / DVI Mode Selection ---
                                - HDMI Mode
                                setenv vout "hdmi"
                                - DVI Mode (disables sound over HDMI as per DVI compat)
                                setenv vout "dvi"
                                --- CPU Governor Setup ---
                                Uncomment only one line. New governor is set after 90secs after boot.
                                - Performance (Keep all the CPU's at Maximum frequency)
                                setenv governor "performance"
                                - Ondemand
                                setenv governor "ondemand"
                                - Interactive (Pretty much just like ondemand with more possible customization via sysfs.)
                                setenv governor "interactive"
                                - Conservative (Like ondemand, but do the frequency transitions more slowly, great for battery powered applications)
                                setenv governor "conservative"
                                - Powersave (Keeps the CPU's to the lowest possible temps)
                                setenv governor "powersave"
                                --- HDMI CEC Configuration ---
                                setenv cecenable "false" # false or true
                                set to true to enable HDMI CEC
                                HDMI Hot Plug detection
                                Forces the HDMI subsystem to ignore the check if the cable is connected or
                                not.
                                false : disable the detection and force it as connected.
                                true : let cable, board and monitor decide the connection status.
                                default: true
                                setenv HPD "false"
                                setenv hdmi_phy_control "HPD=${HPD} vout=${vout}"
                                setenv zimage_addr_r 0x40008000
                                setenv uInitrd_addr_r 0x42000000
                                setenv fdtbin_addr_r 0x44000000
                                setenv fdt_high "0xffffffff"
                                DRAM Frequency (lpddr3 available frequency list - 933/825/728/633)
                                setenv ddr_freq 933
                                set DDR frequency
                                dmc ${ddr_freq}
                                Default boot arguments
                                setenv bootrootfs "label=RECALBOX"
                                setenv console "console=ttySAC2,115200n8 consoleblank=0 vt.global_cursor_default=0"
                                boot commands
                                fatload mmc 0:1 ${zimage_addr_r} ${zimage}
                                fatload mmc 0:1 ${uInitrd_addr_r} ${uInitrd}
                                fatload mmc 0:1 ${fdtbin_addr_r} ${fdtbin}
                                fdt addr 0x44000000
                                if test "${cecenable}" = "false"; then fdt rm /cec@101B0000; fi
                                setenv bootargs "${bootrootfs} ${console} governor=${governor} ${videoconfig} ${hdmi_phy_control}"
                                bootz ${zimage_addr_r} ${uInitrd_addr_r} ${fdtbin_addr_r}
                                • davidb2111
                                  also found this https://wiki.odroid.com/odroid-xu4/application_note/hdmiphy_configuration
                                  Worth a try.
                                  Do not forget to not use drm_kms_helper modes.
                                  • f00f00t
                                    @davidb2111 OK,
                                    I will ttry that as well, below is the output from your first request
                                    Fresh install of 7.2
                                    • HTTP(s) access
                                    • SSH access
                                    • No image on monitor
                                      https://transfer.sh/D0np5/recalbox-support-8622f3eb-cfd3-b88f-97c6-e15a03732d37.tar.gz
                                    after reboot with the resolution helper
                                    • HTTP(s) access
                                    • SSH access
                                      https://transfer.sh/zpEU2/recalbox-support-46347b43-111e-07db-6ab3-a19fa07eb1ce.tar.gz
                                    dmesg
                                    [ 0.000000] Booting Linux on physical CPU 0x100
                                    [ 0.000000] Linux version 5.4.77 (root@3f470502ff33) (gcc version 10.2.0 (Buildroot 2020.11-dirty)) #1 SMP PREEMPT Fri Apr 23 02:11:35 CEST 2021
                                    [ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
                                    [ 0.000000] CPU: div instructions available: patching division code
                                    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                                    [ 0.000000] OF: fdt: Machine model: Hardkernel Odroid XU4
                                    [ 0.000000] Memory policy: Data cache writealloc
                                    [ 0.000000] cma: Reserved 128 MiB at 0xb6800000
                                    [ 0.000000] Samsung CPU ID: 0xe5422001
                                    [ 0.000000] On node 0 totalpages: 518656
                                    [ 0.000000] Normal zone: 1728 pages used for memmap
                                    [ 0.000000] Normal zone: 0 pages reserved
                                    [ 0.000000] Normal zone: 196608 pages, LIFO batch:63
                                    [ 0.000000] HighMem zone: 322048 pages, LIFO batch:63
                                    [ 0.000000] Running under secure firmware.
                                    [ 0.000000] percpu: Embedded 20 pages/cpu s52428 r8192 d21300 u81920
                                    [ 0.000000] pcpu-alloc: s52428 r8192 d21300 u81920 alloc=20*4096
                                    [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
                                    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516928
                                    [ 0.000000] Kernel command line: label=RECALBOX console=ttySAC2,115200n8 consoleblank=0 vt.global_cursor_default=0 governor=performance drm_kms_helper.edid_firmware=edid/1920x1080.bin HPD=false vout=hdmi s5p_mfc.mem=16M
                                    [ 0.000000] [drm] drm_kms_helper.edid_firmware is deprecated, please use drm.edid_firmware instead.
                                    [ 0.000000] hdmi: using HDMI mode
                                    [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                                    [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                    [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                                    [ 0.000000] Memory: 1906832K/2074624K available (10240K kernel code, 781K rwdata, 2748K rodata, 1024K init, 323K bss, 36720K reserved, 131072K cma-reserved, 1157120K highmem)
                                    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
                                    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
                                    [ 0.000000] Tasks RCU enabled.
                                    [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                    [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                    [ 0.000000] GIC: Using split EOI/Deactivate mode
                                    [ 0.000000] random: get_random_bytes called from start_kernel+0x330/0x50c with crng_init=0
                                    [ 0.000000] Switching to timer-based delay loop, resolution 41ns
                                    [ 0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                                    [ 0.000007] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
                                    [ 0.000030] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 49
                                    [ 0.001639] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
                                    [ 0.001658] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
                                    [ 0.001679] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                                    [ 0.001692] Ignoring duplicate/late registration of read_current_timer delay
                                    [ 0.002228] Console: colour dummy device 80x30
                                    [ 0.002270] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
                                    [ 0.002286] pid_max: default: 32768 minimum: 301
                                    [ 0.002486] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                    [ 0.002510] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                    [ 0.003583] CPU: Testing write buffer coherency: ok
                                    [ 0.004157] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
                                    [ 0.005046] Setting up static identity map for 0x40100000 - 0x40100060
                                    [ 0.005335] ARM CCI driver probed
                                    [ 0.005900] Exynos MCPM support installed
                                    [ 0.006177] rcu: Hierarchical SRCU implementation.
                                    [ 0.008627] soc soc0: Exynos: CPU[EXYNOS5800] PRO_ID[0xe5422001] REV[0x1] Detected
                                    [ 0.009123] smp: Bringing up secondary CPUs ...
                                    [ 0.010079] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
                                    [ 0.011146] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
                                    [ 0.012157] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
                                    [ 0.013207] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
                                    [ 0.013216] CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
                                    [ 0.014349] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
                                    [ 0.014357] CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
                                    [ 0.015460] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
                                    [ 0.015468] CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
                                    [ 0.016590] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
                                    [ 0.016598] CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
                                    [ 0.016788] smp: Brought up 1 node, 8 CPUs
                                    [ 0.016806] SMP: Total of 8 processors activated (384.00 BogoMIPS).
                                    [ 0.016814] CPU: All CPU(s) started in HYP mode.
                                    [ 0.016821] CPU: Virtualization extensions available.
                                    [ 0.017918] devtmpfs: initialized
                                    [ 0.036871] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
                                    [ 0.037324] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                    [ 0.037345] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
                                    [ 0.039789] pinctrl core: initialized pinctrl subsystem
                                    [ 0.042119] NET: Registered protocol family 16
                                    [ 0.045203] DMA: preallocated 2048 KiB pool for atomic coherent allocations
                                    [ 0.046590] audit: initializing netlink subsys (disabled)
                                    [ 0.046800] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
                                    [ 0.047500] cpuidle: using governor menu
                                    [ 0.047870] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                                    [ 0.047882] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                    [ 0.112593] EXYNOS5420 PMU initialized
                                    [ 0.226834] iommu: Default domain type: Translated
                                    [ 0.227286] usbcore: registered new interface driver usbfs
                                    [ 0.227343] usbcore: registered new interface driver hub
                                    [ 0.227484] usbcore: registered new device driver usb
                                    [ 0.228083] s3c-i2c 12c80000.i2c: slave address 0x00
                                    [ 0.228101] s3c-i2c 12c80000.i2c: bus frequency set to 65 KHz
                                    [ 0.228353] s3c-i2c 12c80000.i2c: i2c-2: S3C I2C adapter
                                    [ 0.228887] mc: Linux media interface: v0.10
                                    [ 0.228934] videodev: Linux video capture interface: v2.00
                                    [ 0.229045] pps_core: LinuxPPS API ver. 1 registered
                                    [ 0.229055] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
                                    [ 0.229477] Advanced Linux Sound Architecture Driver Initialized.
                                    [ 0.230286] clocksource: Switched to clocksource mct-frc
                                    [ 0.270317] random: fast init done
                                    [ 0.955355] VFS: Disk quotas dquot_6.6.0
                                    [ 0.955429] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                                    [ 0.966387] thermal_sys: Registered thermal governor 'step_wise'
                                    [ 0.968641] NET: Registered protocol family 2
                                    [ 0.969305] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                    [ 0.969339] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                                    [ 0.969419] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                    [ 0.969577] TCP: Hash tables configured (established 8192 bind 8192)
                                    [ 0.969683] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                                    [ 0.969729] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                                    [ 0.969954] NET: Registered protocol family 1
                                    [ 0.970795] RPC: Registered named UNIX socket transport module.
                                    [ 0.970808] RPC: Registered udp transport module.
                                    [ 0.970819] RPC: Registered tcp transport module.
                                    [ 0.970830] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                    [ 0.971051] Trying to unpack rootfs image as initramfs...
                                    [ 0.979471] Freeing initrd memory: 1264K
                                    [ 0.980905] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
                                    [ 0.981652] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
                                    [ 0.985528] Initialise system trusted keyrings
                                    [ 0.985767] workingset: timestamp_bits=14 max_order=19 bucket_order=5
                                    [ 0.994726] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                    [ 0.995527] NFS: Registering the id_resolver key type
                                    [ 0.995557] Key type id_resolver registered
                                    [ 0.995568] Key type id_legacy registered
                                    [ 0.995590] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                    [ 0.995632] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
                                    [ 1.026557] Key type asymmetric registered
                                    [ 1.026572] Asymmetric key pa**er 'x509' registered
                                    [ 1.026631] bounce: pool size: 64 pages
                                    [ 1.026670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
                                    [ 1.026922] io scheduler mq-deadline registered
                                    [ 1.026935] io scheduler kyber registered
                                    [ 1.027070] io scheduler bfq registered
                                    [ 1.029522] samsung-usb2-phy 12130000.phy: 12130000.phy supply vbus not found, using dummy regulator
                                    [ 1.030538] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus not found, using dummy regulator
                                    [ 1.030636] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus-boost not found, using dummy regulator
                                    [ 1.030999] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus not found, using dummy regulator
                                    [ 1.031087] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus-boost not found, using dummy regulator
                                    [ 1.039415] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
                                    [ 1.039433] dma-pl330 121a0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
                                    [ 1.041958] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
                                    [ 1.041975] dma-pl330 121b0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
                                    [ 1.042854] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
                                    [ 1.042870] dma-pl330 10800000.mdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
                                    [ 1.111065] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
                                    [ 1.113283] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 62, base_baud = 0) is a S3C6400/10
                                    [ 1.981048] printk: console [ttySAC2] enabled
                                    [ 1.987027] exynos-trng 10830600.rng: Exynos True Random Number Generator.
                                    [ 1.993344] exynos-mixer 14450000.mixer: Adding to iommu group 0
                                    [ 2.001017] exynos-drm-g2d 10850000.g2d: Adding to iommu group 1
                                    [ 2.007069] exynos-rotator 11c00000.rotator: Adding to iommu group 2
                                    [ 2.019308] mali 11800000.gpu: Failed to get regulator
                                    [ 2.023002] mali 11800000.gpu: Power control initialization failed
                                    [ 2.039674] brd: module loaded
                                    [ 2.055525] loop: module loaded
                                    [ 2.057959] libphy: Fixed MDIO Bus: probed
                                    [ 2.061615] usbcore: registered new interface driver r8152
                                    [ 2.066797] usbcore: registered new interface driver cdc_ether
                                    [ 2.072594] usbcore: registered new interface driver cdc_subset
                                    [ 2.080613] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                    [ 2.085702] ehci-exynos: EHCI EXYNOS driver
                                    [ 2.090207] exynos-ehci 12110000.usb: EHCI Host Controller
                                    [ 2.095334] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
                                    [ 2.103254] exynos-ehci 12110000.usb: irq 79, io mem 0x12110000
                                    [ 2.122337] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
                                    [ 2.127155] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                                    [ 2.135134] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 2.142319] usb usb1: Product: EHCI Host Controller
                                    [ 2.147170] usb usb1: Manufacturer: Linux 5.4.77 ehci_hcd
                                    [ 2.152541] usb usb1: SerialNumber: 12110000.usb
                                    [ 2.157699] hub 1-0:1.0: USB hub found
                                    [ 2.160902] hub 1-0:1.0: 3 ports detected
                                    [ 2.165746] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                    [ 2.171013] ohci-exynos: OHCI EXYNOS driver
                                    [ 2.175345] exynos-ohci 12120000.usb: USB Host Controller
                                    [ 2.180546] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
                                    [ 2.188279] exynos-ohci 12120000.usb: irq 79, io mem 0x12120000
                                    [ 2.254565] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
                                    [ 2.261380] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 2.268865] usb usb2: Product: USB Host Controller
                                    [ 2.273332] usb usb2: Manufacturer: Linux 5.4.77 ohci_hcd
                                    [ 2.278702] usb usb2: SerialNumber: 12120000.usb
                                    [ 2.283839] hub 2-0:1.0: USB hub found
                                    [ 2.287061] hub 2-0:1.0: 3 ports detected
                                    [ 2.293127] mousedev: PS/2 mouse device common for all mice
                                    [ 2.298435] i2c /dev entries driver
                                    [ 2.323521] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
                                    [ 2.340909] vddq_mmc2: Bringing 3300000uV into 2800000-2800000uV
                                    [ 2.361617] vdd_sd: Bringing 3300000uV into 2800000-2800000uV
                                    [ 2.440971] s5m-rtc s2mps14-rtc: registered as rtc0
                                    [ 2.444953] s2mps11-clk s2mps11-clk: DMA mask not set
                                    [ 2.452354] s5p-jpeg 11f50000.jpeg: Adding to iommu group 3
                                    [ 2.456845] s5p-jpeg 11f50000.jpeg: encoder device registered as /dev/video20
                                    [ 2.463758] s5p-jpeg 11f50000.jpeg: decoder device registered as /dev/video21
                                    [ 2.470690] s5p-jpeg 11f50000.jpeg: Samsung S5P JPEG codec
                                    [ 2.476333] s5p-jpeg 11f60000.jpeg: Adding to iommu group 4
                                    [ 2.482020] s5p-jpeg 11f60000.jpeg: encoder device registered as /dev/video22
                                    [ 2.488968] s5p-jpeg 11f60000.jpeg: decoder device registered as /dev/video23
                                    [ 2.495906] s5p-jpeg 11f60000.jpeg: Samsung S5P JPEG codec
                                    [ 2.502049] s5p-mfc 11000000.codec: Adding to iommu group 5
                                    [ 2.524600] s5p-mfc 11000000.codec: preallocated 16 MiB buffer for the firmware and context buffers
                                    [ 2.532284] s5p-mfc 11000000.codec: Direct firmware load for s5p-mfc-v8.fw failed with error -2
                                    [ 2.540892] s5p_mfc_load_firmware:69: Firmware is not present in the /lib/firmware directory nor compiled in kernel
                                    [ 2.551431] s5p-mfc 11000000.codec: decoder registered as /dev/video10
                                    [ 2.557899] s5p-mfc 11000000.codec: encoder registered as /dev/video11
                                    [ 2.566254] exynos-gsc 13e00000.video-scaler: Adding to iommu group 6
                                    [ 2.572417] exynos-gsc 13e10000.video-scaler: Adding to iommu group 7
                                    [ 2.588159] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
                                    [ 2.595597] device-mapper: uevent: version 1.0.3
                                    [ 2.599875] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
                                    [ 2.624357] sdhci: Secure Digital Host Controller Interface driver
                                    [ 2.629068] sdhci: Copyright(c) Pierre Ossman
                                    [ 2.633579] Synopsys Designware Multimedia Card Interface Driver
                                    [ 2.639936] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode.
                                    [ 2.646349] dwmmc_exynos 12200000.mmc: Using internal DMA controller.
                                    [ 2.652642] dwmmc_exynos 12200000.mmc: Version ID is 250a
                                    [ 2.658036] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 81,64 bit host data width,64 deep fifo
                                    [ 2.667459] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq
                                    [ 2.672831] mmc_host mmc0: card is non-removable.
                                    [ 2.694060] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
                                    [ 2.715159] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
                                    [ 2.720610] dwmmc_exynos 12220000.mmc: Using internal DMA controller.
                                    [ 2.727003] dwmmc_exynos 12220000.mmc: Version ID is 250a
                                    [ 2.732383] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 82,64 bit host data width,64 deep fifo
                                    [ 2.756895] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
                                    [ 2.772418] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
                                    [ 2.780983] ledtrig-cpu: registered to indicate activity on CPUs
                                    [ 2.787530] s5p-secss 10830000.sss: s5p-sss driver registered
                                    [ 2.792562] hidraw: raw HID events driver (C) Jiri Kosina
                                    [ 2.805127] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp
                                    [ 2.810466] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp
                                    [ 2.816974] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp
                                    [ 2.823562] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp
                                    [ 2.830390] exynos-ppmu: new PPMU device registered 10d00000.ppmu (ppmu-event3-dmc0_0)
                                    [ 2.832253] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
                                    [ 2.835797] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
                                    [ 2.839192] exynos-ppmu: new PPMU device registered 10d10000.ppmu (ppmu-event3-dmc0_1)
                                    [ 2.849862] mmc1: new ultra high speed SDR104 SDHC card at address 0007
                                    [ 2.858161] exynos-ppmu: new PPMU device registered 10d60000.ppmu (ppmu-event3-dmc1_0)
                                    [ 2.866832] mmcblk1: mmc1:0007 SD32G 29.0 GiB
                                    [ 2.872704] exynos-ppmu: new PPMU device registered 10d70000.ppmu (ppmu-event3-dmc1_1)
                                    [ 2.883925] mmcblk1: p1 p2 p3
                                    [ 2.894735] exynos5-dmc 10c20000.memory-controller: DMC initialized, in irq mode: 0
                                    [ 2.895560] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
                                    [ 2.906212] exynos-adc 12d10000.adc: IRQ index 1 not found
                                    [ 2.923342] NET: Registered protocol family 17
                                    [ 2.926355] NET: Registered protocol family 15
                                    [ 2.930783] Key type dns_resolver registered
                                    [ 2.935367] Registering SWP/SWPB emulation handler
                                    [ 2.939874] registered taskstats version 1
                                    [ 2.943821] Loading compiled-in X.509 certificates
                                    [ 2.948687] Key type ._fscrypt registered
                                    [ 2.952571] Key type .fscrypt registered
                                    [ 2.957250] Key type encrypted registered
                                    [ 2.993458] exynos-asv 10000000.chipid: cpu0 opp0, freq: 1500 missing
                                    [ 2.998480] exynos-asv 10000000.chipid: cpu4 opp0, freq: 2100 missing
                                    [ 3.008082] OF: graph: no port node found in /soc/hdmi@14530000
                                    [ 3.014806] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations
                                    [ 3.021268] exynos-drm exynos-drm: bound 14450000.mixer (ops 0xc0b6da68)
                                    [ 3.027818] exynos-drm exynos-drm: bound 14530000.hdmi (ops 0xc0b6e0ec)
                                    [ 3.034697] exynos-drm-g2d 10850000.g2d: The Exynos G2D (ver 4.1) successfully registered.
                                    [ 3.042599] exynos-drm exynos-drm: bound 10850000.g2d (ops 0xc0b6f034)
                                    [ 3.049110] exynos-rotator 11c00000.rotator: The exynos rotator has been probed successfully
                                    [ 3.057496] exynos-drm exynos-drm: bound 11c00000.rotator (ops 0xc0b6f8c0)
                                    [ 3.064341] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                                    [ 3.070925] [drm] No driver support for vblank timestamp query.
                                    [ 3.077186] [drm] Cannot find any crtc or sizes
                                    [ 3.082089] [drm] Cannot find any crtc or sizes
                                    [ 3.086394] [drm] Initialized exynos 1.1.0 20180330 for exynos-drm on minor 0
                                    [ 3.096066] mali 11800000.gpu: GPU identified as 0x0620 r0p1 status 0
                                    [ 3.102025] mali 11800000.gpu: Protected mode not available
                                    [ 3.108147] mali 11800000.gpu: Probed as mali0
                                    [ 3.113237] dwc3 12000000.dwc3: Failed to get clk 'ref': -2
                                    [ 3.118138] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
                                    [ 3.122860] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
                                    [ 3.130850] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
                                    [ 3.139904] xhci-hcd xhci-hcd.8.auto: irq 159, io mem 0x12000000
                                    [ 3.146411] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                                    [ 3.154020] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 3.161210] usb usb3: Product: xHCI Host Controller
                                    [ 3.166061] usb usb3: Manufacturer: Linux 5.4.77 xhci-hcd
                                    [ 3.171434] usb usb3: SerialNumber: xhci-hcd.8.auto
                                    [ 3.176870] hub 3-0:1.0: USB hub found
                                    [ 3.180052] hub 3-0:1.0: 1 port detected
                                    [ 3.184277] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
                                    [ 3.189379] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
                                    [ 3.197005] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed
                                    [ 3.203610] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
                                    [ 3.211740] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
                                    [ 3.214554] devfreq 11800000.gpu: Couldn't update frequency transition information.
                                    [ 3.219806] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 3.219812] usb usb4: Product: xHCI Host Controller
                                    [ 3.219817] usb usb4: Manufacturer: Linux 5.4.77 xhci-hcd
                                    [ 3.219822] usb usb4: SerialNumber: xhci-hcd.8.auto
                                    [ 3.234553] hub 4-0:1.0: USB hub found
                                    [ 3.253474] hub 4-0:1.0: 1 port detected
                                    [ 3.259807] dwc3 12400000.dwc3: Failed to get clk 'ref': -2
                                    [ 3.264517] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
                                    [ 3.269406] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
                                    [ 3.277387] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
                                    [ 3.286468] xhci-hcd xhci-hcd.9.auto: irq 160, io mem 0x12400000
                                    [ 3.292895] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                                    [ 3.300587] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 3.307787] usb usb5: Product: xHCI Host Controller
                                    [ 3.312628] usb usb5: Manufacturer: Linux 5.4.77 xhci-hcd
                                    [ 3.318000] usb usb5: SerialNumber: xhci-hcd.9.auto
                                    [ 3.323394] hub 5-0:1.0: USB hub found
                                    [ 3.326608] hub 5-0:1.0: 1 port detected
                                    [ 3.330821] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
                                    [ 3.335946] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
                                    [ 3.343569] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed
                                    [ 3.350165] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
                                    [ 3.358331] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
                                    [ 3.366355] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [ 3.373546] usb usb6: Product: xHCI Host Controller
                                    [ 3.378414] usb usb6: Manufacturer: Linux 5.4.77 xhci-hcd
                                    [ 3.383770] usb usb6: SerialNumber: xhci-hcd.9.auto
                                    [ 3.389158] hub 6-0:1.0: USB hub found
                                    [ 3.392378] hub 6-0:1.0: 1 port detected
                                    [ 3.397598] s3c-rtc 101e0000.rtc: rtc disabled, re-enabling
                                    [ 3.401969] rtc rtc1: invalid alarm value: 1900-01-15T00:00:00
                                    [ 3.407793] s3c-rtc 101e0000.rtc: registered as rtc1
                                    [ 3.415430] exynos-bus: new bus device registered: soc:bus_wcore ( 84000 KHz ~ 400000 KHz)
                                    [ 3.423239] exynos-bus: new bus device registered: soc:bus_noc ( 67000 KHz ~ 100000 KHz)
                                    [ 3.430993] exynos-bus: new bus device registered: soc:bus_fsys_apb (100000 KHz ~ 200000 KHz)
                                    [ 3.439247] exynos-bus: new bus device registered: soc:bus_fsys (100000 KHz ~ 200000 KHz)
                                    [ 3.447726] exynos-bus: new bus device registered: soc:bus_fsys2 ( 75000 KHz ~ 150000 KHz)
                                    [ 3.456197] exynos-bus: new bus device registered: soc:bus_mfc ( 96000 KHz ~ 333000 KHz)
                                    [ 3.464144] exynos-bus: new bus device registered: soc:bus_gen ( 89000 KHz ~ 267000 KHz)
                                    [ 3.471877] exynos-bus: new bus device registered: soc:bus_peri ( 67000 KHz ~ 67000 KHz)
                                    [ 3.480484] exynos-bus: new bus device registered: soc:bus_g2d ( 84000 KHz ~ 333000 KHz)
                                    [ 3.488415] exynos-bus: new bus device registered: soc:bus_g2d_acp ( 67000 KHz ~ 267000 KHz)
                                    [ 3.496818] exynos-bus: new bus device registered: soc:bus_jpeg ( 75000 KHz ~ 300000 KHz)
                                    [ 3.504959] exynos-bus: new bus device registered: soc:bus_jpeg_apb ( 84000 KHz ~ 167000 KHz)
                                    [ 3.513222] exynos-bus: new bus device registered: soc:bus_disp1_fimd (120000 KHz ~ 200000 KHz)
                                    [ 3.521987] exynos-bus: new bus device registered: soc:bus_disp1 (120000 KHz ~ 300000 KHz)
                                    [ 3.530254] exynos-bus: new bus device registered: soc:bus_gscl_scaler (150000 KHz ~ 300000 KHz)
                                    [ 3.539274] exynos-bus: new bus device registered: soc:bus_mscl ( 84000 KHz ~ 400000 KHz)
                                    [ 3.552579] s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01T00:00:08 UTC (946684808)
                                    [ 3.608139] ALSA device list:
                                    [ 3.609644] No soundcards found.
                                    [ 3.616315] Freeing unused kernel memory: 1024K
                                    [ 3.622979] Run /init as init process
                                    [ 3.674674] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
                                    [ 3.704941] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice=92.22
                                    [ 3.711692] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                                    [ 3.719757] usb 4-1: Product: USB3.0 Hub
                                    [ 3.722712] usb 4-1: Manufacturer: GenesysLogic
                                    [ 3.728146] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
                                    [ 3.748524] hub 4-1:1.0: USB hub found
                                    [ 3.751248] hub 4-1:1.0: 2 ports detected
                                    [ 3.817580] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
                                    [ 3.826335] usb 3-1: new high-speed USB device number 2 using xhci-hcd
                                    [ 3.869025] /dev/loop0: Can't open blockdev
                                    [ 3.872319] /dev/loop0: Can't open blockdev
                                    [ 3.982751] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.22
                                    [ 3.989463] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                                    [ 3.996596] usb 3-1: Product: USB2.0 Hub
                                    [ 4.000471] usb 3-1: Manufacturer: GenesysLogic
                                    [ 4.068143] hub 3-1:1.0: USB hub found
                                    [ 4.070731] hub 3-1:1.0: 2 ports detected
                                    [ 4.538424] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
                                    [ 4.563286] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
                                    [ 4.570003] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
                                    [ 4.577103] usb 6-1: Product: USB 10/100/1000 LAN
                                    [ 4.581777] usb 6-1: Manufacturer: Realtek
                                    [ 4.585850] usb 6-1: SerialNumber: 000001000000
                                    [ 4.662299] dwmmc_exynos 12220000.mmc: Unexpected command timeout, state 3
                                    [ 4.806937] usb 6-1: reset SuperSpeed Gen 1 USB device number 2 using xhci-hcd
                                    [ 4.880599] r8152 6-1:1.0 eth0: v1.10.11
                                    [ 5.244407] udevd[230]: starting version 3.2.9
                                    [ 5.268181] random: udevd: uninitialized urandom read (16 bytes read)
                                    [ 5.273276] random: udevd: uninitialized urandom read (16 bytes read)
                                    [ 5.279783] random: udevd: uninitialized urandom read (16 bytes read)
                                    [ 5.303894] udevd[231]: starting eudev-3.2.9
                                    [ 5.344451] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
                                    [ 5.349620] dma-pl330 3880000.adma: DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
                                    [ 5.358681] samsung-i2s 3830000.i2s-sec: DMA channels sourced from device 3830000.i2s
                                    [ 5.369874] odroid-audio sound: snd-soc-dummy-dai <-> samsung-i2s mapping ok
                                    [ 5.375586] odroid-audio sound: i2s-hifi <-> snd-soc-dummy-dai mapping ok
                                    [ 5.383428] odroid-audio sound: snd-soc-dummy-dai <-> samsung-i2s-sec mapping ok
                                    [ 5.389778] dma-pl330 3880000.adma: PM domain MAU will not be powered off
                                    [ 5.543130] gpiomem-exynos 13400000.gpiomem: Initialised: GPIO register area is 2
                                    [ 5.549424] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x13400000
                                    [ 5.557055] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x14010000
                                    [ 5.564437] input: gpio_keys as /devices/platform/gpio_keys/input/input0
                                    [ 5.858339] random: crng init done
                                    [ 5.860259] random: 3 urandom warning(s) missed due to ratelimiting
                                    [ 6.476816] Bluetooth: Core ver 2.22
                                    [ 6.479503] NET: Registered protocol family 31
                                    [ 6.483510] Bluetooth: HCI device and connection manager initialized
                                    [ 6.489711] Bluetooth: HCI socket layer initialized
                                    [ 6.494540] Bluetooth: L2CAP socket layer initialized
                                    [ 6.499591] Bluetooth: SCO socket layer initialized
                                    [ 6.520896] 8021q: 802.1Q VLAN Support v1.8
                                    [ 6.558511] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                    [ 6.562380] Bluetooth: BNEP filters: protocol multicast
                                    [ 6.567585] Bluetooth: BNEP socket layer initialized
                                    [ 6.592365] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                    [ 6.645281] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                    [ 6.743287] r8152 6-1:1.0 eth0: carrier on
                                    [ 6.877096] fuse: init (API version 7.31)
                                    [ 9.812400] usbcore: registered new interface driver usbhid
                                    [ 9.816572] usbhid: USB HID core driver
                                    [ 10.231599] NET: Registered protocol family 10
                                    [ 10.235721] Segment Routing with IPv6
                                    [ 33.759599] vdd_ldo12: disabling
                                    davidb2111 1 Reply Last reply Reply Quote 0
                                    • davidb2111
                                      davidb2111 Staff @f00f00t last edited by
                                      @f00f00t
                                      That's a very odd issue you've got here... I don't have any idea to solve that.
                                      I can eventually b*mp linux kernel and get a test image for you, as a last resort...
                                      • ianmcc1
                                        ianmcc1 last edited by
                                        i did a fresh install of the 7.2v on my odroid xu4 and i have the same problem, fan spins up and then stops, no video output. my v4 runs just fine. i would really like to get the new version on there tho.
                                        would installing an older working version and somehow dumping the new image into the shared folder over the network work?
                                        • ianmcc1
                                          hey i was having the same problems you were, but i got mine working, heres how i did it
                                          dont unzip the image file, drag and drop it directly into the program you use to flash your drive. i dont know what the difference was but it booted up no problem
                                          • f00f00t
                                            @davidb2111 ok great.
                                            I'm happy to do any testing for you and give log data and reports needed.
