    Supervision folder and games extension.
    Emulator Arcade/PC/Console
    extension supervision
    2689
    • jorgemagana
      jorgemagana last edited by jorgemagana
      Hello, thanks for 7.2 release!
      I have a some questions about supervision:
      1. What is the differencie between Epoch super cassete vision and Watara vision?
      2. supervision readme file says thats needs games with .sv extension, those are for Watara. For Epoch o Yeno SCV ¿which files are correct? ¿Do I need to put them in other folder?
      3. Also, ARRM scraper doesn't recognize supervision folder as a system. So, it is impossible to scrap.
      I am confused, thanks.
        Scavy Global moderator @jorgemagana last edited by
        @jorgemagana hello
        1/ they are two different game consoles
        Epoch SCV : https://en.wikipedia.org/wiki/Super_Cassette_Vision
        Watara Supervision : https://fr.wikipedia.org/wiki/Watara_Supervision
        2/ Is there a readme file in the scv folder ?
        3/ you have to ask to @nexusone13
        jorgemagana nexusone13 2 Replies Last reply Reply Quote 0
        • jorgemagana
          jorgemagana @Scavy last edited by
          @Scavy Thanks!
          • nexusone13
            nexusone13 @Scavy last edited by
            Hi @Scavy @jorgemana
            SCV (Super Cassette Vision) is supported since ARRM 1890 with scv folder name (with extension .bin and .zip)
            I don't know if Watara supervision is used in Recalbox, so I didn't add it ... I don't know its folder name and authorized extensions ... so if you have the information, I'm interested . .. 🙂
            @jorgemagana , if you want to add a new system on ARRM you can follow this wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=different_systems_name_en
            Scavy jorgemagana 2 Replies Last reply Reply Quote 0
              Scavy Global moderator @nexusone13 last edited by
              @nexusone13 said in Supervision folder and games extension.:
              it's avaible on v7.2 😉
              • jorgemagana
                jorgemagana @nexusone13 last edited by
                Thanks, this new system added in 7.2 has the folder "supervision" and extensions .sv and .zip
                nexusone13 3 Replies Last reply Reply Quote 0
                • nexusone13
                  nexusone13 @jorgemagana last edited by
                  This post is deleted!
                  • nexusone13
                    @jorgemagana said in Supervision folder and games extension.:
                    It's for Watara or Epoch ?
                    • Pitch64
                      Pitch64 Staff last edited by Pitch64
                      Watara Supervision:
                      • .sv
                      • .zip
                      Epoch Super Cassette Vision:
                      • .bin
                      • .cart
                      • .zip
                      Next release? Soon™
                      nexusone13 1 Reply Last reply Reply Quote 1
                      • nexusone13
                        nexusone13 @Pitch64 last edited by
                        @Pitch64 said in Supervision folder and games extension.:
                        Watara Supervision:
                        • .sv
                        • .zip
                        • .bin
                        • .cart
                        • .zip
                        Thanks !!!!
                        • nexusone13
                          @jorgemagana available in ARRM 1892 BETA v4 (Executable only + templates + some config files) for testing
                          !! You must have at least 1.8.9.1 version installed !!
                          download link : http://jujuvincebros.fr/telechargements2/file/96-arrm-beta-1-8-9-2-v4-for-testing-executable-only-templates
                          jorgemagana 1 Reply Last reply Reply Quote 0
                          • jorgemagana
                            @nexusone13 thanks!
