    Update to 7.2 --> no sound
    Emulator Arcade/PC/Console
    update 7.2 sound
    11
    31
    9741
    • Salva_Davila
      Salva_Davila @neo207 last edited by
      @neo207 That fix the black screen on KODI problem. In spanish, use translator: https://malagaoriginal.blogspot.com/2021/04/actualizar-recalbox-711-72-solucionado.html
      neo207 1 Reply Last reply Reply Quote 1
      • tellymaneli
        tellymaneli last edited by
        Hello, I also updated. Splash screen and roms with no sound. Recalbox menu with sound. I use 3.5 jack / sound and HDMI for the monitor. Now I have completely replayed everything. Splash doesn't work but Recalbox Menu and Rom :-). I strongly suspect that there is a bug here. Entries in Alsmixer are also not saved after a restart.
        • neo207
          neo207 @Salva_Davila last edited by neo207
          @Salva_Davila OK THANK YOU FOR THE LINK, I used PUTTY in order to access my recalbox via ssh (i had to learn that, i hadn't done this before).
          I restarted...
          Spash Screen ---> has sound again
          Kodi ---> no black screen, videos are working!!!
          mame/neogeo games ---> sound is back!!! (what the heck was that?!?! it works!!!)
          but meh... all mame games have the neo geo bezel now AND the games are not in the center of the screen but somehow bigger and moved to right-down.
          IS There anyone who could help with this weird glitch which I got by fixing everything else with the help of Salva-Davila ?
          I have to laugh right now, because I seem to be so close to the solution but still, something else is broken 🙂
          • neo207
            neo207 @Ry0san01 last edited by
            @Ry0san01 said in Update to 7.2 --> no sound:
            Pour information les problĂšmes de son semblent survenir suite Ă  la montĂ©e de version sur rpi 4 (mĂȘme peut ĂȘtre aussi sur d’autres support ??) de 7.1.1 vers 7.2 si vous avez un support externe en plus de la sd card. Je viens de faire un reset usine sur la sd card et tout est ok : son et touche psx du core rearmed. Je suis en train de recrĂ©er ma clĂ© usb Ă  partir de la sd card suite Ă  reset usine. AprĂšs quelques tests tout semble ok now.
            i don't understand everything but yes, i am using a raspberry pi 4 with 4gb ram
              Zing Global moderator Translator @neo207 last edited by
              @neo207 Have you tried the factory reset that was suggested?
              The reset will keep all your personal data, but it will reset all settings.
              About kodi, this topic is in English and talks about the temporary solution:
              https://forum.recalbox.com/topic/23883/radpberry-pi4-kodi-black-screen-7-2/7
              Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
              • breakbob
                breakbob last edited by
                I had no in-game sounds but after restoring ES to Factory settings I can confirm the sound is back. Still don't know how to mix in-game sounds with custom music I put for ES main menu.
                • Vacrial
                  Vacrial last edited by Vacrial
                  I have a solution
                  be sure that you recalbox is connected to internet (wifi).
                  Run a command dos
                  type :
                  ssh recalbox -l root
                  (-l set the login)
                  When SSH ask you to enter password type
                  recalboxroot
                  Now you can set the audio.
                  Type F6 to select sound output.
                  Choose heaphone (or your output)
                  Now you see the volum bar of you headphone output.
                  Put it to 100% to solve your problem
                  Vacrial 1 Reply Last reply Reply Quote 0
                  • Vacrial
                    Vacrial @Vacrial last edited by
                    @Vacrial i forgot to say that after you enter the password and loggued in, run the tool :
                    alsamixer
                    and then you can set the audio.
                    neo207 1 Reply Last reply Reply Quote 0
                    • neo207
                      neo207 @Vacrial last edited by
                      @vacrial said in Update to 7.2 --> no sound:
                      alsamixer
                      thank you but i eventually solved it by reseting everything and updating to 7.2.1 but now there is another bug -->
                      RETURNING FROM KODI TO RECALBOX MAKES THE MUSIC VERY LOUD. You solve this by lowering the volume, in my case from 50% to 49% and back to 50% again.
                      I hope there is a fix soon because i switch between kodi and recalbox quite often.
                      • alexlibertador
                        alexlibertador @Salva_Davila last edited by
                        This post is deleted!
                        • alexlibertador
                          @salva_davila said in Update to 7.2 --> no sound:
                          @neo207 Think about it. I have lost the language settings, wifi, gpio, shaders, etc, and in my case, the sound still does not work. Neither changing the driver to pulse as they say in another post.
                          Edit: Ok, after a reboot the sound does work when choosing "pulse" in the retroarch audio menu (tab or HK + B).
                          this works for me. thank you
                          100.3k
