    Radpberry pi4 kodi black screen 7.2
    MediaCenter & Dualboot
    radpberry pi4 kodi 7.2
    10
    15
    5198
    • nebura45
      nebura45 last edited by
      With the 7.2 update kodi is not able to play any video. Just a black screen without sound. Tested with local and streaming videos.
      silky89 1 Reply Last reply Reply Quote 0
      • cdtpepette
        cdtpepette last edited by
        Same problem using usb and nfs sources.
        Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
        Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
        • silky89
          silky89 @nebura45 last edited by
          @nebura45 same issues here on RPI4 no video from SMB share. Tried to find some threads about this online, tried to change the HDMI port but still the same. Didn't try to play something from USB storage.
          • Jesús BL
            Jesús BL last edited by
            I also have the same problem.
            Raspberry pi 400.
            Trucos y recetas para raspberry pi:
            http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
            • cdtpepette
              cdtpepette last edited by cdtpepette
              Temporary solution (thanks to @Pitch64 on discord ) to fix problem with black screen and cec not working:
              With ssh:
              mount -o remount,rw /boot
              nano /boot/config.txt
              search for dtoverlay=vc4-kms-v3d and modify with dtoverlay=vc4-fkms-v3d
              Save file (Ctrl + o)
              Reboot
              Jesús BL RB2021 edwinsources 3 Replies Last reply Reply Quote 3
              • Jesús BL
                Jesús BL @cdtpepette last edited by
                @cdtpepette Thanks for the solution and so fast!
                • abepdita
                  abepdita last edited by
                  Thanks a lot for the solution. Can someone explain how this change affects Kodi behavior? I ask this because I experience decreased performances when watching some h264 videos.
                  Thank you in advance.
                  • RB2021
                    RB2021 @cdtpepette last edited by
                    @cdtpepette
                    thanks for the help, but.... how can I use this script ? Noobs question, where do i enter it ? A terminal window ? and how ?
                    Sorry for so candid question...
                    Thanks for the help anyway !
                    Shinshiva 1 Reply Last reply Reply Quote 0
                    • Shinshiva
                      Shinshiva @RB2021 last edited by Shinshiva
                      @RB2021 You must log on your rasp through ssh (putty.exe by example) and follow the indication written before.
                      You might find your rasp IP on your network, on the Recalbox UI or by other means.
                      Default credentials are well known by all (root / recalboxroot) but i'll advice you to change them later on
                      You'll need to know a lil' bit about how to modify a file with nano but i guess it can be handled even without documentation.
                      I'm not myself a linux master, far from it, i'll try to add some precision on how i handle theses :
                      Step by step
                      • mount -o remount,rw /boot
                        #It allows enough permission to proceed
                      • nano /boot/config.txt
                        #It open the config.txt file with the nano tool
                      • search for dtoverlay=vc4-kms-v3d and modify with dtoverlay=vc4-fkms-v3d
                        #You'll have to navigate into the config.txt to find the following info and change it
                      • Save file (Ctrl + o)
                        #For myself, i do CTRL+X (to quit after change) , then Y (to say Yes to over write file), then enter to get out.
                      • Reboot
                        #Just type it in, or reboot by other means
                      Hope it helps ya ! From the noob i am too 😛
                      RB2021 Scavy 2 Replies Last reply Reply Quote 4
                      • RB2021
                        RB2021 @Shinshiva last edited by
                        Thanks a lot @Shinshiva for taking time to answer me !
                        I'll try ,I'll learn 😉
                        enjoy your day !
                          Scavy Global moderator @Shinshiva last edited by
                          @Shinshiva thanx, commands with clear explanations, i love these kind of posts 😉
                          • Shinshiva
                            You are welcome ! Pas d'quoi 😉
                            My family needed Kodi (& my Nas content) to survive this era 😄 So the @Pitch64 workaround helped a lot !
                            RB2021 1 Reply Last reply Reply Quote 0
                            • RB2021
                              @Shinshiva
                              Yes it worked !
                              Indeed : best explainatiions ever !
                              Merci 😉
                              • fdivita
                                fdivita last edited by
                                Thanks for the solution you save my day 😉
                                • edwinsources
                                  edwinsources @cdtpepette last edited by
                                  @cdtpepette the only method that worked for me, but it doesn't give me sound
                                  • Locked by  Zing Zing
