    [SOLVED] Installing Bios (how?and problems...)
    [solved] installing bios howand
    • chamilonster
      chamilonster last edited by
      Hi, first of all i was read this: https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN) (and i can not understand very well) so i download the mst MD5 but it says "This program has expired. please look www.mstsoftware.com for a new version" so i go to http://mstsoftware.com/ to download the program but the web page says: "mst software is offline. We stopped our business. Thanks for your support." so we will need another program for bios... can i use this? http://www.winmd5.com/ but i can not understand exactly whats i have to do, i think is (for example crash bandicoot psx): i have to take the md5 checksum from  crash bandicolt.img and paste into the file SCPH1001.BIN  on the bios folder, so inside the file only you will see 924e392ed05558ffdb115408c263dccf Is that right?
      • i_am_millski
        i_am_millski last edited by
        I encountered the same problem of mstsoftware being out of date 😕 I use the tool from here: www.WinMD5.com instead. Just run the tool and point it at your BIOS file (SCPH1001.BIN) and make sure the code matches the code on the RecalBox wiki. - PLAYSTATION : 924e392ed05558ffdb115408c263dccf SCPH1001.BIN
        Geek, car nut, gamer, photographer and I enjoy pastries
        • peterpan123123
          peterpan123123 last edited by
          Just copy the needed bios (in your case SCPH1001.BIN) to /recalbox/share/bios/ or better upload via Webpage of your recalbox, because there it checks the checksum and tells you, if you have the right bios or not. You do not have to edit the SCPH1001.BIN.
            Link if need : https://github.com/recalbox/recalbox-os/wiki/Check-md5-checksum-(FR) https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
            • chamilonster
              ok, i found the bios surfing the net, i think is ilegal to post it here... soo.. search it =D and compare the md5 thanks...
