    Suggestion for N64 controller?
    GamePad/GPIO/USB encoder
    suggestion
    • Quarron
      Quarron last edited by
      I just updated my GPi and Pi3 Box from recalbox 6 to 7.
      After that, I (again) tried to set up my 8bitdo N64 controllers to work with recalbox.
      Well. There is no success to tell. I just can't get it to work ... so still no N64 games 😞
      Because it never really worked and these controllers are no longer listed on any official 8bitdo product lists, I think about buying new controllers for N64 games. Because of the Z trigger and the 4 additional C-buttons, I find it quite hard to play N64 games with other controllers.
      So my question to other recalbox users is:
      Has any of you found a recommendable N64 that works good with recalbox and mupen?
      Or, alternativly, has anyone succeeded in setting up the 8bitdo controller and would share how to do it?
      Regards from Augsburg from a N64 fan,
      Michael
        Zing Global moderator Translator @Quarron last edited by
        @Quarron See if this helps:
        • https://forum.recalbox.com/topic/9016/a-lire-manettes-n64
        • https://forum.recalbox.com/topic/22474/conseils-de-manette-pour-n64
        • https://forum.recalbox.com/topic/22845/config-manette-pour-libretro_mupen64
        • neo207
          neo207 last edited by
          perfect:
          https://www.amazon.de/iNNEXT-Controller-Joystick-PC-Controller-Raspberry-Color-1/dp/B07B666WN6/ref=sr_1_10?__mk_de_DE=ÅMÅŽÕÑ&crid=3OX3Z6YCZH34A&dchild=1&keywords=n64+controller+usb&qid=1619884723&sprefix=n64+cont%2Caps%2C191&sr=8-10
