    Problem with GPIO
    gpio
    • darth
      darth last edited by
      Hello team, how are you doing?
      I installed the new recalbox 7.1.1 RELOADED.
      I have a portable case (GAME HAT),
      The manufacturer indications to make it work through GPIO is the following:
      on recalbox.conf edit this:
      controllers.gpio.enabled=1 (change 0 to 1)
      and this:
      ##controller.gpio.args=map=1,2
      controllers.gpio.args=map=5 gpio=5,6,13,19,21,4,26,12,23,20,16,18,-1
      I have been using this on recalbox 6.1.1, with this exact configuration and worked good, but when I tried this on 7.1.1 it does not work.
      Any ideas? Thank you
      • darth
        I forgot to add that I am using Raspberry Pi 3b+
        • ian57
          ian57 Staff @darth last edited by
          @darth said in Problem with GPIO:
          that's really strange, there's normally no problem and it was tested
          Can you send an archive support please.
          • darth
            Thank you for the response, I did a new clean install and it worked.
            Something went wrong during the migration from 6.11 to 7.1.1
            Thanks.
            101.4k
