    retroarch won't save gamepad bindings
    GamePad/GPIO/USB encoder
    retroarch wont gamepad bindings
    • DaFunkShun
      DaFunkShun last edited by
      I have no idea what I am doing wrong and need help please!
      I setup my hotkey bindings in the configuration menu of retroarch without having a core loaded (Settings - > Input -> Hotkeys)
      and when done save them in the main menu (Main Menu -> Configuration File -> Save Current Configuration).
      This worked perfectly.
      I then loaded a core (Flycast) and all my settings are gone, retroarch loading retroarchcustom.cfg instead of retroarch.cfg
      I redid all my key bindings and saved them as current configuration under the same name (retroarchcustom.cfg) but my settings are not saved and I have to rebind my hotkeys every time I start a game.
      I then edited the retroarchcustom.cfg manually and added the hotkeys but found out that retroarch just recreates a 'default' retroarchcustom.cfg every time it loads Flycast.
      What am I missing ?
      • Locked by  Pitch64 Pitch64
      • Restored by  Pitch64 Pitch64
      100.7k
