    Can't pair bluetooth joysticks
    GamePad/GPIO/USB encoder
    cant pair bluetooth joysticks
    • FunkySonicO
      FunkySonicO last edited by
      Hi everyone, i have one problem while pairing the joysticks, I have a Raspberry 3 with Recalbox 7.1.1 before that with dragon blaze and working PS3. At first after updating recalbox the controllers worked fine but don't know why they stopped worked and like recalbox reset all the configs.
      Well, now while pairing 3 bluetooth joysticks recalbox does not recognize them. If i enter from my pc to my recalbox ip and going into controllers can't change bluez or official, in brief i can't enter controllers menu, it stays as loading...
      Any help!?
        Zing Global moderator Translator @FunkySonicO last edited by
        @FunkySonicO Apparently your SHARE partition has been corrupted, try to recover it on Windows using a USB adapter.
        Unfortunately, if that doesn't work, I recommend that you back up and redo the installation.
        Perhaps this video will help you:
        https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23&ab_channel=Recalbox
        FunkySonicO 1 Reply Last reply Reply Quote 0
        • FunkySonicO
          FunkySonicO @Zing last edited by
          @Zing thanks but isn't corrupted amigo, checking recalbox.conf i see missing bluetooth lines so i added them. Apparently if you delete all the connected peripherals the configuration in the file is also deleted... Now is fixed so problem resolved.
          Anyway thanks for your reply!!
