    Steamlink possible?
    steamlink possible
    • NiceMarmut
      NiceMarmut last edited by
      Is it possible to get Steamlink in the Ports section?
      I had it running on my RetroPie, but then I realized that mechanism is different on Recalbox. I thought there might be some command line instructions.
      I know Moonlight is possible, but I only have an AMD card.
      loscar78 1 Reply Last reply Reply Quote 0
      • loscar78
        loscar78 @NiceMarmut last edited by
        @NiceMarmut said in Steamlink possible?:
        Dear all,
        Is there any plan to have Recalbox able to launch Steam Link App (as it's possible with Retropie)?
        Thanks!
        • Magaki
          Magaki last edited by
          Hello,
          Specifically Steam Link app, no. But you have an open-source alternative with Moonlight.
          I'm not using it, unfortunately, difficult to help you, but you can check this on Wiki : https://wiki.recalbox.com/en/tutorials/games/moonlight/moonlight-setup
          • loscar78
            loscar78 @Magaki last edited by
            Thanks a lot @Magaki!
