    Space Invaders Question
    Emulator Arcade/PC/Console
    space invaders
    • sroach
      sroach last edited by
      Hey Folks,
      a question about the original version of the 1978 game Space Invaders.
      Invaders.zip from what I can tell is the original arcade rom from Taito.
      The game works, the sample files provide the sound correctly but there seems to be a lag when I push fire.
      Honestly I am not sure I remember if that is how it worked from the original game?
      Any one have a different experience with the game?
      • barbudreadmon
        barbudreadmon @sroach last edited by barbudreadmon
        @sroach said in Space Invaders Question:
        Maybe depends on the emulator you are using, here using FBNeo i got 1 frame of input lag, which is probably the minimum you'll ever achieve in an emulator without enabling runahead (enabling runahead removes that frame of input lag).
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
