    Recalbox 7.1.1 not booting Pi 4
    recalbox 7.1.1 booting
    • mdimart
      mdimart last edited by
      Hello, I am VERY new to Raspberry Pi and really not a Linux person. I am hoping someone can help with my issue. When I install Recalbox on an SD card and try to boot, I see a red and green light on the PI but it never loads. I just get a black screen and eventually the red light just shows on the Pi. I have tried the official Pi Imager software, PINN, three different SD cards (2 were 128GB class 10 cards and one was a 16GB class 4 card). I am able to load PI OS and Twister without issue on these SD cards, so I am not sure what is wrong.
      I tried loading the image using Windows and then Ubuntu and it made no difference. I tried restoring the overclock of the CPU/GPU back down to defaults as well. I had the same issue with a black screen and no booting when I tried to install and boot NOOBs as well.
      I have also tried a different monitor and HDMI cable (I am plugged into the HDMI closest to the power plug)
      I am not sure what to look at next. Is it the boot file on the PI? Could I have a defective PI board? Any suggestions would help. Thanks. BTW: I have a PI 4 with 4GB RAM and I am using the Argon One V2 case)
        Zing Global moderator Translator @mdimart last edited by
        @mdimart Remove from the case and test it to see if it is not the case that is causing the problem.
        What is your power supply?I s it offering the necessary energy?
        How are you installing Recalbox on the SD card? Did you download the correct version for your card? The official version?
        Test with an original SD card, class 10, maximum 16gb (SD cards class 4 are not recommended, and SD cards as big as 128gb are also not, I do not rule out the possibility of being the SD card).
        Test with another HDMI port too, not only with an HDMI port.
        • mdimart
          Hello Zing. I am using a CanaKit 3.5A Raspberry Pi 4 Power Supply so I don't think that is the issue. I tried loading Recalbox using PINN, Pi Imager, and Etcher using the official image for Pi4/Pi400 download from this site. I tried multiple SD cards with no luck, but all were 128GB Class 10 cards. I don't have any 16GB class 10 cards so I can't try that at the moment. I have tried loading other OS's such as Raspberry Pi OS, Twister OS, and Retropie and did not have any issues on the same SD card.
            Zing Global moderator Translator @Zing last edited by
            @mdimart
            • DirtyScumbeast
              DirtyScumbeast last edited by
              did you use the installer from this website? Id recommend that & get the one for the right version of Pi you have.
              Try a different micro SD card to make sure its not that too.
              try a different install of OS from the installer, to test the PI is working too.
