    Raspberry Pi Imager Bricked My SD Card
    bricked card imager
    • Cykoth
      Cykoth last edited by Cykoth
      Hi. I'm brand new here. I'm sorry I don't have any images as this all happened in real time and I thought I could salvage my 64GB SD card. So I had this card left over from an old Galaxy phone I had. It was formatted in ex-FAT. I know RB-Pi needs FAT file allocation, but I saw this Raspberry Pi imager program on Recalbox and thought all this would just work. Things were writing along and I stepped away. I came back to my computer and had an error message that something went wrong, and that I may have a bad drive. Prior to this there was nothing wrong with the SD Card. It was addressable by Win 10, had data on it, and I even made a backup of that data prior to doing all this. I deleted the data existing on the drive and ran the Imager then BRICK. So then I downloaded Etcher. And really had to be careful not to accidentally install a bunch of crapware btw. But while Etcher saw the drive it also ran into an error when I just tried to flash directly with the RB Pi 4 image. So I'm concerned about just buying another card and it being bricked also.
      Anyone have any thoughts or similar experiences? Thanks so much!
      Cykoth 1 Reply Last reply Reply Quote 0
      • Cykoth
        Cykoth @Cykoth last edited by Cykoth
        So I had another 8GB SD card I wanted to test. I just went straight to Etcher. This card already was formatted FAT32. Using the image file recalbox-rpi4.img.xz.Image of Etcher Brick.png
          Hello
          replace your sdcard or adapter.
          It's not software problem, but hardware problem
          • Cykoth
            Cykoth @acris last edited by
            @acris So I don't really know how you know that......
            But I did order a new 64GB SD Card from Amazon. I used the same adapter from my prior experience. I got it to work, but for others who were in my position and would like a step by step this is EXACTLY what I did:
            1. Insert the SD Card into the adapter and then the adapter into the computer. I made sure Win 10 could recognize it and verified that the format was ex-FAT.
            2. I then ran the SD Card Formatter application from https://www.sdcard.org/downloads/formatter_4/index.html
              version 5.0.1.
            3. I then launched the 1.5 version of Raspberry Pi Imager and selected Erase (format card as FAT32).
            4. I then selected Emulation and game OS and navigated to Recalbox 7.1.1. This time it worked!
            So even if you have a SDXC card that is functional, things seem very "tweaky" when you try to set them up for formats they were not designed to support (obviously).
            Hope this helps others!
