    Super Mario RPG
    Emulator Arcade/PC/Console
    mario rpg
    7
    10
    7713
    • twitch
      twitch last edited by
      The game tells me to disconnect the 4-Player Adapter... Any chance to solve this?   Rgds Dario
      • aameiel
        aameiel last edited by
        b*mp i would love to know the awnser to this also
          voljega Banned last edited by
          Try another SNES emulator for that game you can do that from Emulation Station menu
          • aameiel
            Changed the emulater for just that game and it works like a charm!!! Thank you for your suggestion.
            • brian-crail
              brian-crail last edited by
              I have experienced this as well. Here is the fix: Go into the actual Emulator settings (HotKey + B) and input options. Set Player 3-5 to Disabled or none, then set Player 2 to just a controller or disable it. In the same menu options, about halfway down there is an option to Save Input Config and Save Input Game Config (which I assume will save it to only launch with that game). I just disable it for ALL games as I only intend on having 2 players max. Yoshi's Island and other FX based SNES games do not support Multitap and will fail to load.
                Yeah I would say don't give a half baked solution which will give trouble to many people when there is already in the thread a simple, perfectly working response without any side effect
                • Dinierto
                  Dinierto Banned last edited by
                  I'm trying to set the gamepads to disabled but I don't see the "input options" anywhere. There are input settings but they are different from described.
                  Nachtgarm Substring 2 Replies Last reply Reply Quote 0
                  • Nachtgarm
                    Nachtgarm @Dinierto last edited by
                    @Dinierto Just use another core for the game. As already stated above by @voljega. It's the easiest solution.
                    • Select the game in ES
                    • Hit SELECT
                    • EDIT META DATA
                    • Change emulator to libretro
                    • choose any other core instead of snes9x
                    This issue has been discussed in the forum several times. Please use the search function
                      Substring @Dinierto last edited by
                      @Dinierto follow nachtgarm's recommendation. Whay you look for is in quick options > controls, where the P2 input is set on multitap
                      Dinierto 1 Reply Last reply Reply Quote 0
                      • Dinierto
                        Dinierto Banned @Substring last edited by
                        @subs said in Super Mario RPG:
                        Yeah I found it last night, that fixed it. Thanks! Maybe I'm being weird but I'd like to use SNES9X Next for everything.
