    Kein wlan
    kein wlan
    • BoB
      BoB last edited by
      Hallo liebe recalbox gemeinde.
      Ich habe ein pi 400 und bekomme keine verbindung zum internet per wlan. Es wird mir eine ip adresse angezeigt, aber keine verbindung. Hatte den normalen pi 4. Da hatte es ohne probleme funktioniert.
      Bin um jede hilfe dankbar.
        Zing Global moderator Translator @BoB last edited by
        @BoB Please, in the international part of the Forum, speak in English.
        See if this helps:
        https://forum.recalbox.com/topic/22856/recalbox-7-1-1-wifi-not-working-not-connecting
        • ebepat
          ebepat last edited by
          Hallo bob,
          Ich habe das gleich problem. Funktioniert es jetzt bei dir?
          Gruss
          BoB 1 Reply Last reply Reply Quote 0
          • BoB
            BoB @ebepat last edited by
            @ebepat hallo
            Das verrückte ist das es sporadisch geht. Wenn ich das wlan im menü öfters ein und ausschalte hat es letztes mal funktioniert. Dann neu gestartet wieder ohne funktion. Ich probiere noch ein bisschen weiter aus.
            • fredisback81
              fredisback81 last edited by fredisback81
              @BoB
              @ebepat
              As already mentioned from @Zing check my thread if that helps:
              I had the problem that WPA2 with SHA256 was enabled in my router menu / options in wireless security, however this does not work because of a bug in the current version 7.1.1. I tested various options and created an issue for resolving the bug for the project on gitlab, the issue has been found and will be fixed with the next release, check (recalbox developers on gitlab):
              https://gitlab.com/recalbox/recalbox/-/issues/1492
              a. Check your router menu / wireless and security options
              As workaround please set "WPA2 only" (e.g. with AES etc.) but without "SHA256" in your router menu.
              b. Check your recalbox.conf file, if the following is set:
              region is set to FR or JP? In my case, US worked as well
              enable ertm = 1
              Do you have any special chars in your PW? In the recalbox.conf it is mentioned that you need to escape these special chars, but it seems that this is not needed anymore.
              Cheers,
              fredisback81
              RPi 3b+ with Nespi Case - Recalbox v8
              101.4k
