    7.1.1 RPi0w first boot doesn't end
    7.1.1 rpi0w boot doesnt end
    • ericball
      ericball last edited by
      Used Raspberry Pi Imager to image 4Gb microSD card (speed unknown) - booted on RPi0w without modifying config.txt etc.
      Connected to 1600x1200@60 Dell 2007FB LCD via mini HDMI to DVI cable, power provided by monitor (powered hub), USB SNES controller, USB headset & wireless USB keyboard & mouse via monitor hub. Config works with Lakka (after removing hdmi_group=1 from config.txt include) and RetroPi 4.5/4.7 (ex sound).
      Recalbox booted and eventually the splash screen with the Pacman ghosts appeared. The SD activity light has been flashing for several hours, but I have no idea what it is doing and whether I just need to wait longer or if I start over with a bigger & faster microSD.
        Zing Global moderator Translator @ericball last edited by
        @ericball During the first boot, the SHARE partition is created, so this is the slowest boot, but it shouldn't be more than 15 min on such a small Sd card.
        Original and class 10 SD cards are recommended, but I cannot guarantee that this is the problem.
        Have you tried to redo the installation, to ensure that there were no random problems in the process?
        • ericball
          Thanks for responding so quickly.
          I recreated the image and no change to the result. It doesn't appear that any partitions have been created, it still only has the FAT32 RECALBOX partition.
          As the FAT32 RECALBOX partition only uses 756Mb of the 3070Mb partition I resized it down to 800Mb and that completed the first boot successfully and now I'm at the main menu (on the ZX Spectrum).
          Any reason the FAT32 RECALBOX has so much free space? Other distros seem to ship with a minimal FAT32 partition.
            @ericball
            Sorry, but this is not how it works: if the system did not create the SHARE partition, your night was not successful, probably the problem is the quality of your SD card, I recommend testing with another one.
            You should not change the size of the main partitions, the only partition you can shrink is the SHARE partition if you want to use dual boot with another system. the partitions are the necessary size, there is no "needlessly left", the space is "reserved for updates / temporary files / etc", there is a reason, it is not an error.
