    GPi Case forces PiSnes
    Emulator Arcade/PC/Console
    gpi case forces pisnes
    • thehaze34
      thehaze34 last edited by
      I have Recalbox 7.1.1 running on a PiZero W in a GPi Case.
      Every time the system starts up the Emulator setting for SNES is set to "PISnes".
      I want to use Snesx2002 because PiSnes does not support the retroarch menu by Hotkey + Y and also does not support Retroachievements.
      I can change the settings of course, but they are not saved after the GPi was shut down. For other systems the settings are stored, however.
      The problem is: If I forget to set to Snesx2002 and start a game with PiSnes, the savegame is completely lost.
      How to fix this behaviour?
      thanks
        Zing Global moderator Translator @thehaze34 last edited by
        @thehaze34
        How are you doing this? If you don't want to change the default emulator for all games on a given console, just go to the Emulationstation main menu, Advanced Emulator Configuration, choose the console you want to change the default emulator for, and change it.
        Or, if you prefer, you can also configure some things with Configuration overload:
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
        thehaze34 1 Reply Last reply Reply Quote 1
        • thehaze34
          thehaze34 @Zing last edited by
          @Zing
          Changing in the advanced emulator settings only works for the current session and setting is lost after GPI switched off.
          Next time you switch on the gpi case the emulator is set to PISNES again.
          On other systems setting is saved, for example if I setup GBA emulator.
          But now I tried to edit the Metadata and it looks like this settings are stored.
          So I need to change for every single game, but this seems to work.
            @thehaze34
            See the links I posted, it will make it easier for you.
            thehaze34 1 Reply Last reply Reply Quote 0
            • thehaze34
              @Zing
              I will try as well.
              Thanks.
