    Recalbox 7.1.1 Freeze on my Odroid XU4
    recalbox 7.1.1 odroid xu4
    • Federiko
      Federiko last edited by
      Hi,
      I installed many times the Recalbox 7.1.1 on my Odroid XU4 because after 4 or 5 reboot I don't know the reason the system is freeze but I can use the ssh, What I can do?
      Is a Recalbox OS problem?
      Thanks.
        Zing Global moderator Translator @Federiko last edited by
        @Federiko
        I believe not, otherwise more users would be reporting.
        You can use some SSH command:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/dossiers-et-commandes-ssh
        But, you need to find out what you're doing wrong, problems like that usually happen by:
        • Incompatible theme (using the default theme solves the problem)
        • Low quality storage device (original class 10 SD cards are recommended)
        • Corrupted storage device (plugging the storage device into windows and checking for errors can resolve)
        • Shutting down the system wrongly / Removing power without shutting down the system (you need to shut down correctly through the main menu)
        • Some kind of mishandling (the user just needs to analyze what is changing before the system crashes)
