    MSX/MSX2 correct file bios match MD5
    bios correct file match md5
    • Space81
      Space81 last edited by Zing
      Hi everyone, I have walked the length and breadth of the network, but I cannot find the following correct bios files of the MSX / MSX2:
      -MSX2P.rom
      -MSX.rom
      -BEERIDE.rom
      -MICROSOLDISK.rom
      -MSX2SE.rom
      -MSXFR.rom
      -MSXSP.rom
      Very thanks.
      Alexandre M Zing 2 Replies Last reply Reply Quote 0
      • Alexandre M
        Alexandre M @Space81 last edited by
        @Space81
        Bonjour.
        Je ne pense pas que tu auras ici des renseignements sur ou trouver les bios, enfin si c' est ce que tu cherche.
        Pour le MD5 il est affiché dans la gestion des bios de la Recalbox ;).
        RECALBOX 7.1.1:
        Boîtier NESPI 4 Case: Raspberry Pi 4 : 2GB | Alim officiel USB-C | Câble Micro-HDMI vers HDMI
        MicroSD: Sandisk Ultra 16Go
        DD: SSD WD BLUE 500 Go
        Joy: 8BitDo SN30 Pro Plus Bluetooth (MAJ)
        Internet: Ethernet (Fibre)
        • Space81
          @Alexandre-M said in MSX/MSX2 correct file bios match MD5:
          Bonjour.
          ok thank you, but they are the only bios I can't find.
            Zing Global moderator Translator @Space81 last edited by
            @Space81 It is against the forum rules to solicit or share any type of copyrighted material.
