    Set up emulators for PAL crt-tv
    pal crt-tv
    • IGA
      IGA last edited by
      Hello)
      Could somebody there help me with running emulators on PAL crt-tv via composit on RP4?
      I write in config file lines:
      enable_tvout=1
      sdtv_mode=2
      sdtv_aspect=1
      to enable composite output
      It's work, but slow 50 fps\Hz, so gameplay and sound very different from normal ntsc-roms running. And blackboards on top and down of screen also available.
      So, i need set up all emulators to run at 60hz (60fps) with normal speed and sound. How?
      ( TV has support 60 Hz)
      • nmichael200
        nmichael200 last edited by nmichael200
        Good evening.
        Alas, the PAL standard makes sense to use 50 hertz. You need to use the NTSC standard there is just 60 hertz.
        sdtv_mode=0 or 1
        audio_pwm_mode=0
        Read https://4pda.ru/forum/index.php?showtopic=802556&view=findpost&p=87392162 only on russian.
        • IGA
          IGA last edited by
          Yes, but in NTSC i've got black-white color picture on my tv or wrong color in ntsc 3,58 mode of my tv.
          So. i've would like boot raspberry in pal, but emulators sets in ntsc.
          • can i do it? It's possible at all?
          @nmichael200 said in Set up emulators for PAL crt-tv:
          • Yeah, iam from there, and asked it too....
