    Solved Installation of recalbox hungs with colorful window
    installation recalbox hungs colorful window
    • jakubm82
      jakubm82 last edited by
      Hi,
      I am using raspberryPi 3b+ and wanted to install recalbox 4.1
      When I copied all files from the installation package to my sd card (32GB) formatted to FAT32, and inserted it to raspberry nothing happens.
      I power up the box and only a colorful window appears 😕
      Can you help please?
        Recalbox 4.1 is not compatible ! It s very old!
        Download raspberry pi imager and use 7.1.1
        https://download.recalbox.com/fr/
        • jakubm82
          Ok, thanks! Currently on it.
