    Solved Im new and need help whit my pi4 4gb with recalbox sound lags
    need help whit pi4 4gb recalbox sound lags
    • Atli25
      Atli25 last edited by
      I just set it up and got all the right Bios of psx Im mainly running pa1 games on it
      all my games load up and run like they should but the sound is lagging so mush.
      Im not well into this just found out about raspberry pi two weeks ago. I have been using youtube as my guide to the set up and Im sure I did that correctly since everything runs fine except the sound.
      • degomax
        degomax last edited by
        Hi Atli25,
        I have exactly the same issue on my rpi4, but in all emulators not only psx and on the default installation, but the sound is ok and no lag on Recalbox menu and in Kodi. It comes only on games.
        It works great with no lags on my rpi 3 b and my rpi 3b+, but not on my pi 4
        Yesterday I posted this issue on the French forum, I am waiting for any information for it.
        For now to get rid of this lag, It seems that to force the HDMI in 720p (hdmi group and mode) in the config.txt resolves the trouble (I have tested only 5 times and turn off and on system, each time and it is ok for now)
        tell me if it solves your problem too.
        • Atli25
          I fix it!!.
          the problem was the shaders and shaders set
          my game settings are:
          GAME RATIO: auto
          SMOOTH GAME: on
          SHADERS: 4xbr retro.glslp
          SHADERS SET scanlines
          hope this halps you
          • Referenced by  jamesssbot jamesssbot
