    Trackball Motion Issues
    GamePad/GPIO/USB encoder
    trackball motion
    • arcadezz
      arcadezz last edited by
      Hello, I have a ps2 trackball that works over USB(with adapter) or PS2, but the motion is very bad. It skips alot and gets stuck alot, goes in the wrong direction, etc.....games are unplayable in MAME. If I hook it up to windows and run the same games in MAME on windows, it works perfectly.
      I really like Recalbox and have been trying for days to get it working properly with no luck.....Can anyone help and suggest how to fix this?
      Thanks.
        Zing Global moderator Translator @arcadezz last edited by
        @arcadezz See if these links (although old) help you:
        • https://forum.recalbox.com/topic/20179/rbx6-1-1-x86_64-trackball-mame2003-or-2003-plus-pointer-moves-but-no-control-in-game
        • https://forum.recalbox.com/topic/18659/set-up-usb-trackball-in-recalbox
        • arcadezz
          I managed to fix this, in RetroArch under Settings, Drivers, I changed Input & Controller to "udev"...... worked perfectly now. Hopefully someone else finds this useful. Thanks.
          101.4k
