    ROMS ON NAS
    roms nas
    • Gigi20
      Gigi20 last edited by
      There a guide to have roms external at the sd card on a external DISK.
      I have a nas synology, is possible to move the roms there?
      Thank You
      Giulio
        Zing Global moderator Translator @Gigi20 last edited by
        @Gigi20 See if this link helps you:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/reseau/partage/charger-ses-roms-depuis-un-partage-reseau-samba-un-nas-par-exemple
        • LucZarganoff
          LucZarganoff last edited by
          Hello.
          I have a problem following the tutorial :
          I did create a "share" folder on my Synology with all the subdirectories of the "recalbox/share" directory.
          I created a user "recalbox" with a password
          When editing the "recalbox-boot.conf" I have the following lines :
          sharedevice=NETWORK
          sharenetwork_smb=SHARE@192.168.0.20:share:username=recalbox,password=XXXXXXXX, vers=3.0
          sharewait=30
          I think my sharenetwork line is unproprer, but the examples in the tutorial doesn't help (seems that the example is with à windows shared folder).
          I tried with different versions of SMB (2.0/2.1, 3.0)
          I tried nfs.
          The Synology NAS tell me that the user recalbox is connected, but my recalbox is still exploring the SDcard directory instead of the NAS directory.
          Someone to correct me please ?
          What did I miss ?
          Thanks a lot.
          Luc
          • LucZarganoff
            I found the problem : erase the ",vers=3.0" part of the smb config...
            work like a charm !
            Sorry...
            Luc
