    Solved Dreamcast emulator not visible on Recalbox 7.1.1
    Emulator Arcade/PC/Console
    dreamcast visible recalbox 7.1.1
    1965
    • fcouant
      fcouant last edited by
      Hello the community,
      I have a problem with the Dreamcast emulator, I don't see the emulator in the recalbox menu.
      I use version 7.1.1-Reloaded, I have the updated DC bios and in the "roms/dreamcast" folder, I put the roms in .chd, .cdi
      Has anyone ever encountered this problem?
        Hello @fcouant
        your raspberry is not compatible with dreamcast
        https://recalbox.gitbook.io/documentation/hardware-compatibility/emulators-compatibility
        you need to buy pi4 or NUC
          Scavy Global moderator @fcouant last edited by
          @fcouant what is your board ?
          • fcouant
            @Scavy I use a raspberry pi 2 type B - 1GO Ram : Recalbox v7.1.1 and external WD 1 To HDD
              Hello @fcouant
              • fcouant
                Hello @acris
                Thank you for your help. I hadn't seen that part of the documentation. I will have to invest 😁
                • sergioad
                  sergioad last edited by
                  This post is deleted!
