    Xbox one controller BT W/ recall box 7.1.1-reloaded
    GamePad/GPIO/USB encoder
    xbox one controller bluetooth recalbox7 pi4
    • ttvaj
      ttvaj last edited by
      I’ve been successful with pairing my Bluetooth Xbox one controller with Retropie, decided to try out recal box, have been unable thus far to pair the controller.
      I’ve tried mount/remount rw and editing /etc/modprobe.d/Bluetooth.conf but the setting resets itself after reboot. -file is read only, will not edit.
      I’ve tried to edit recalbox.conf
      But the setting makes no difference.
      I can see the controller when I do the search, it just will not pair.
      Running recalbox 7.1.1-reloaded
      Pi4
      Thank you in advance for any help on this.
      Sad to say, I may have to switch back to retropie.
        Zing Global moderator Translator @ttvaj last edited by
        @ttvaj Try this:
        https://forum.recalbox.com/topic/22306/xbox-one-s-controller-unable-to-pair-controller/5
        ttvaj 1 Reply Last reply Reply Quote 0
        • ttvaj
          ttvaj @Zing last edited by
          @Zing thank you. I had tried that previously. I’ve searched the forums ad nauseam to find a fix. But it just will not pair. It’s weird because I can pair it in retropie .
            @ttvaj They are different systems, things don't work exactly the same in all systems, otherwise there would be more than one system.
            I don't have a control like that, and I can't reproduce the problem, I can't test it, but I know that in several bluetooth controls there is more than one pairing mode, I recommend that you test them all (check the manual or the manufacturer's website ).
            Some controls have the possibility to update the firmware, check if this is not the case.
            Some controls need to be paired manually, try:
            https://recalbox.gitbook.io/documentation/v/francais/tutoriels/controleurs/configuration-test/connecter-manuellement-le-controleur-bluetooth
            Try mount -o remount,rw /boot, read this: https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acceder-a-une-partition-en-ecriture
            • nullvolt
              nullvolt last edited by
              @ttvaj have you been able to sort this out? I have exactly the same problem with Nintendo Switch Pro controller(s) https://forum.recalbox.com/topic/22585/unable-to-pair-switch-pro-controller-on-rpi3b-4-with-rb7
