    checksum rpi3 download
    • hyamanieu
      hyamanieu last edited by
      Hi dear devs,
      I have downloaded both recalbox-rpi3.img.xz.sha1 and recalbox-rpi3.img.xz from respectively https://upgrade.recalbox.com/latest/rpi3/recalbox-rpi3.img.xz.sha1 and https://upgrade.recalbox.com/latest/download/rpi3/recalbox-rpi3.img.xz (as on found download.recalbox.com). Well the checksum fails. cat-ing the sha1 file 80e4d0916ef8249aa2d708a13c2f5cfffdf4db30 recalbox-rpi3.img.xz, while sha1suming the downloaded image gives me 23b9693c6d8e04c6841ee4271ae8574a77599e8c recalbox-rpi3.img.xz. I have redownloaded twice. Still same checksum output. Is there an error on the download side or is it from me?
      I have installed Imager 1.4 using Ubuntu's snap. It's failing the install and it can't open the compressed file, so it seems there is an error with it...
      Are there mirror links? Or peer2peer?
        Zing Global moderator Translator @hyamanieu last edited by
        @hyamanieu Try Raspberry Pi Imager.
          Hello @hyamanieu
          try to re-download img.xz, the problem solved.
          unzip and flash with raspberry pi imager.
          • hyamanieu
            Thanks for your response.
            As said in my first post, I did use Imager v1.4
            I will try again this week-end if the new image on the server is good.
