    COTTON 2 on Recalbox?!
    Emulator Arcade/PC/Console
    cotton recalbox
    2358
    • neo207
      neo207 last edited by
      Has anyone managed to play COTTON 2? I can start the game via mame but i play in slow motion, so it is unplayable. the romset should be right (mame2003) so is the game simply not supported yet?
      jonas 1 Reply Last reply Reply Quote 0
      • Scorpio70
        Scorpio70 last edited by
        Cotton 2 works perfectly fine here. Recabox x86/64 version. Perhaps a performance issue with your system (RPI ?)
        neo207 1 Reply Last reply Reply Quote 0
        • neo207
          neo207 @Scorpio70 last edited by
          @Scorpio70 do you use mame or fba / fbneo? can you give a little hint where to find that working rom?
          Scorpio70 1 Reply Last reply Reply Quote 0
          • Scorpio70
            Scorpio70 @neo207 last edited by
            @neo207 My bad, you're right, mame version is slow. You should give a try to saturn version which is nearly the same and runs smoothly...
            • jonas
              jonas @neo207 last edited by
              @neo207 , I've read somewhere that Sega ST-V games (Cotton 2, Cotton Boomerang, Radiant Silvergun and some others) are playable using a RPi4 with AdvanceMAME.
              AdvanceMAME was not working correctly with RB 7.01, but it's supposed to be fixed now with RB 7.1. I have not upgraded from 7.0.1yet, so I cannot confirm.
              • Scorpio70
                many websites indicate major performance loss with cotton 2 and cotton boomerang (among other stv games)
                • neo207
                  thank you, guys. so i guess i have to wait until one of the developers is interested in the game being playable on recalbox (at least with rpi4)
                  • neo207
                    @Scorpio70 so i cannot find a saturn folder in the roms folder. how do you play saturn games on a recalbox? are you using a raspberry pi or are you playing on windows ?
                    • Scorpio70
                      @neo207 i'm playing on a x86_64 system...i didn't know saturn wasn't available on a rpi one
                        saturn only PC.
