    Rii i8+ problem pairing with RP4
    GamePad/GPIO/USB encoder
    rii pairing rp4
    • Fefo81
      Fefo81 last edited by
      Hi guys! I have problems pairing the Rii i8+ mini keyboard to RP4 7.0.1
      I didn’t have any issue with RP3 b 6.0.1. This mini keyboard is sold with a dongle so I needed just to plug it in the RP and it was pairing automatically.
      I have also noticed the mini keyboard is working when I’m really close but not if I’m distancing a little bit. I have done some experiments with my laptop and the keyboard is working perfectly. So it’s an issue with the RP4.
      Cheers
      • Fefo81
        Anyone can help me?
        Cheers
        • JiP
          JiP last edited by
          hi
          work's perfectly out of the box for me (RB7.1.1 w RP4.0 4Gb on USB2 port).
          Mayby power issue. Change for a stronger power supply for RP4 (?)
          Fefo81 1 Reply Last reply Reply Quote 0
          • Fefo81
            Fefo81 @JiP last edited by
            @JiP Thanks for the reply. The power supply is the official one. The only difference with your setup is the ram. I have 2 and you 4.
