    n64 doesn't work
    Your recalbox
    doesnt
    6470
    • JayX
      JayX last edited by
      Hello!
      Is something additional required for running n64 roms? I tried different roms (z64, n64 - all unarchived) on different x86 PCs and no one works.
      Could you help me please?
      Megadrive, nes, snes and many other systems work fine.
      • airdream
        Did you tried another core?
        JayX 1 Reply Last reply Reply Quote 0
        • JayX
          JayX @airdream last edited by
          @airdream no, but I've found out there are problems with bios. I'll try to solve.
          • Pitch64
            Pitch64 Staff last edited by
            There is no bios for n64, only the 64dd which have its own directory.
            Next release? Soon™
            • JayX
              JayX last edited by
              Bios checking showed I didn't have IPL.N64 but I've fixed that. Now bios is green but games still don't work. What can I do?
              • Pitch64
                Pitch64 Staff last edited by Pitch64
                Did you check with others cores?
                If you don't know how to do, there is 2 ways to do it:
                • For all games for a system:
                Start button > Advanced settings > Advanced configuration of the emulator
                Here, you select the wanted system, in this case 'Nintendo 64'. Then, go to Emulator.
                • For a specific game in a system:
                Position yourself to the wanted game > Start button > Edit game data > Emulator.
                For those 2 ways to reach the same setting, you have the available cores for the system. I'll let you to test all available cores to see which one is working for you 🙂
                Next release? Soon™
                JayX 1 Reply Last reply Reply Quote 1
                • JayX
                  JayX @Pitch64 last edited by
                  @Pitch64 yeah, thank you very much for explanation, choosing another emulator solved the problem!
