    Recalbox 7.0.1 Remap pad problem
    Emulator Arcade/PC/Console
    recalbox 7.0.1 remap pad
    2532
    • Benzitor
      Benzitor last edited by
      Hi everyone,
      I have a slight problem with Recalbox 7.0.1. When i try to remap my Ps4 controller ( or other USB 10 buttons ones ) i cannot confirm the remap.
      I do all, and when i have choice between OK and CANCEL ( A or B ) only the B button ( cancel ) works.
      Even enter on keyboard doesn't work.
      What to do...because no hotkey in games is just a pain in the ass.
        Scavy Global moderator @Benzitor last edited by
        @Benzitor hello
        Is your PS4 pad an official une ?
        When you plug it (with a USB câble or bt) isn't it automatically plugged ?
        Benzitor 1 Reply Last reply Reply Quote 0
        • Benzitor
          Benzitor @Scavy last edited by
          @Scavy Yes official. And it works just fine, except the remapping of the controller keys.
          It actually works through, until i need to confirm. At this point, it just doesn't allow me to confirm. i can only cancel.
          It is very frustrating because without a keyboard, i cannot exit games.
          And it does the same with a plugged one, or a Bluetooth one.
            @Benzitor can you connect with SSH and give us the result of this command :
            sdl2-jstest --list
            • Benzitor
              login as: root
              root@192.168.2.42's password:
              sdl2-jstest --list
              error: failed to read gamecontrollerdb.txt: Invalid RWops
              Found 1 joystick(s)
              Joystick Name: 'Wireless Controller'
              Joystick Path: '/dev/input/event3'
              Joystick GUID: 050000004c050000c405000000810000
              Joystick Number: 0
              Number of Axes: 6
              Number of Buttons: 13
              Number of Hats: 1
              Number of B***s: 0
              GameControllerConfig:
              Name: 'PS4 Controller'
              Mapping: '050000004c050000c405000000810000,PS4 Controller,a:b0,b:b1,back:b8,dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b10,leftshoulder:b4,leftstick:b11,lefttrigger:a2,leftx:a0,lefty:a1,rightshoulder:b5,rightstick:b12,righttrigger:a5,rightx:a3,righty:a4,start:b9,x:b3,y:b2,'
              Axis code 0: 0
              Axis code 1: 1
              Axis code 2: 2
              Axis code 3: 3
              Axis code 4: 4
              Axis code 5: 5
              Button code 0: 304
              Button code 1: 305
              Button code 2: 307
              Button code 3: 308
              Button code 4: 310
              Button code 5: 311
              Button code 6: 312
              Button code 7: 313
              Button code 8: 314
              Button code 9: 315
              Button code 10: 316
              Button code 11: 317
              Button code 12: 318
              Hat code 0: 16
                @Benzitor thanx, i ask to the devs.
                • Rafiki
                  Rafiki last edited by
                  Hi @Scavy
                  Have the dev found what was the issue 🙂 ?
                  I have the same problem with a N64 USB controller :
                  sdl2-jstest -l
                  Found 1 joystick(s)
                  Joystick Name: 'SWITCH CO.,LTD. Controller (Dinput)'
                  Joystick Path: '/dev/input/event0'
                  Joystick GUID: 03000000632500007505000011010000
                  Joystick Number: 0
                  Number of Axes: 4
                  Number of Hats: 1
                  Number of B***s: 0
                  missing (see 'gamecontrollerdb.txt' or SDL_GAMECONTROLLERCONFIG)
                  Axis code 0: 0
                  Axis code 1: 1
                  Axis code 2: 2
                  Axis code 3: 5
                  Button code 0: 304
                  Button code 1: 305
                  Button code 2: 306
                  Button code 3: 307
                  Button code 4: 308
                  Button code 5: 309
                  Button code 6: 310
                  Button code 7: 311
                  Button code 8: 312
                  Button code 9: 313
                  Button code 10: 314
                  Button code 11: 315
                  Button code 12: 316
                  Hat code 0: 16
                  Thank you for your help !
                  • thep
                    thep last edited by
                    Hi all,
                    Same problem as @Rafiki with the same controller. Any news on how to fix the mapping?
                    Thank you
                    101.4k
