    Solved MAME - Gamepad PS3 - how-to buttons config?
    Emulator Arcade/PC/Console
    mame gamepad ps3 how-to buttons config
    • fredisback81
      fredisback81 last edited by
      Hi all,
      I've no problems to (automatically) configure my PS3 Gamepad / Bluetooth and use it for a myriad of systems, except MAME / Arcade until now.
      Since most of these ROMs / systems are special, is there another way of configuring input devices / buttons for these arcade / MAME games? Or what is the idea, that each ROM has to be configured on its own (e.g. within Retroarch / Op
      tions / Input configuration ?)
      My specs: rpi 3b+, rb 7.0.1, Gamepad: Standard PS3 Bluetooth
      Thanks,
      fredisback81
      RPi 3b+ with Nespi Case - Recalbox v8
        Zing Global moderator Translator @fredisback81 last edited by
        @fredisback81 said in MAME - Gamepad PS3 - how-to buttons config?:
        You can customize the controls via the Retroarch menu as you mentioned, it is possible to save a configuration by core or by game, as you prefer.
        Another option is to try this with Configuration overload:
        https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
