    Freezing on restart/shutdown
    freezing restartshutdown
    • buggasauras
      buggasauras last edited by
      Hi all,
      I recently enabled volume control via a rotary encoder as decribed here;
      https://recalbox.gitbook.io/tutorials/audio/rotary-encoder-via-gpio-digital-volume-control
      It works great, however now, whenever i shutdown or restart it freezes.
      Can anyone help? Id be very grateful
      Thank you
        Zing Global moderator Translator @buggasauras last edited by
        @buggasauras Sorry, I don't have enough technical knowledge to help you a lot, and I don't even have a way to reproduce this problem, but, you probably made some kind of wrong connection, or there is something wrong in the script configuration. Do you have more things connected at GPIO and are they in conflict maybe?
        buggasauras 1 Reply Last reply Reply Quote 0
        • buggasauras
          buggasauras @Zing last edited by
          @Zing hi,
          Thanks for you input. I have a on/off switch also connected via GPIO. When i disable this the freezing stops
          Zing 2 Replies Last reply Reply Quote 0
            @buggasauras And, are you using the same PIN for both at some point?
            Maybe a GROUND? If so, can you use another GROUND and test it?
              @buggasauras It's not exactly the same subject, but, see if it helps (it's in French, use google translator):
              https://forum.recalbox.com/topic/22366/carte-wm8960-et-bouton-on-off-pin56push
