    n64 controller configuration with mupen64 on 7.0.1
    GamePad/GPIO/USB encoder
    mupen64 7.0.1
    • indeed
      indeed last edited by
      hi everyone,
      I bought 3 n64 controllers (SWITCH CO.,LTD. Controller (Dinput)) which I somehow cant't get use my settings from mupen64plus.cfg.
      When I set n64.configfile=dummy in recalbox.conf the controllers won't work at all, otherwise the default recalbox mapping is used. With n64.configfile=dummy after starting a n64 game a box is shown which tells me the controller is not configured.
      I noticed that neither mupen64plus.conf nor InputAutoCfg.ini are ever updated. Actually InputAutoCfg.ini didn't even exist (I created it on my own just for testing)
      Accoring some thread I deleted mupen64/input.xml, but it was not re-created as well.
      I'm quite sure my mappings are correct, because I crosschecked with a mupen64plus.conf on my computer where the controllers work fine.
      Board Model: raspberry pi 4b
      Sd Card: SanDisk Extreme 128 GB
      Controller: miadore Retro 64-Bit (SWITCH CO.,LTD. Controller (Dinput))
      Emulators: tested all 3
      I found a thread where there same problem was reported, but only after the original problem was already solved:
      https://forum.recalbox.com/topic/21817/generic-usb-n64-controller-config-with-mupen64plus/7
      Regards
        Zing Global moderator Translator @indeed last edited by
        @indeed Try this:
        https://forum.recalbox.com/topic/21653/pi4-recalbox-7-x-mupen64plus-bug-enregistrement-du-mapping-dans-retroarch/65?_=1605037947077
