    Solved BIOS mismatch - even with same MD5?
    bios md5 mismatch same
    • RK.aus.S
      RK.aus.S last edited by RK.aus.S
      Hello
      Eventually, I got all BIOS files for Recalbox 7.0.1 - my BIOS library is 100 complet. But all of a sudden, I noticed that Recalbox complains on one, single BIOS - just since today!? The last time I checked the BIOS section, I sure all BIOS very complet and with correct MD5 checksum.
      Look at my screenshot; it shows the MD5 checksum file of my "scph101.bin" file which I copied to the Recalbox. I've double checked it several times. The BIOS "scph101.bin" which I copied to the bios folder has for sure the same MD5 as requested - nevertheless Recalbox complains about the checksum???
      I noticed that Recalbox displays every BIOS checksum in lower letters, except this one. Could it be, that Recalbox compairs the MD5 somehwo case sesitive?
      Regards
      • RK.aus.S
        Since I couldn't edit my previous post anymore, here an additional information.
        The new BIOS check feature of Recalbox 7 itself doesn't complain about this "scph101.bin" file.
        So it seams (for me) to be quite sure; this could/must be a bug.
        • Pitch64
          Pitch64 Staff last edited by
          The manager is not up to date. Use the bios checker like you did until now 🙂
          Next release? Soonâ„¢
          • RK.aus.S
            Thanks for clarification.
            It's a bit confusing, since this BIOS was regarded as correct all the days before...
            • olivierdroid92
              This post is deleted!
