    Dragon's Lair > MAME / Daphne
    dragons lair mame daphne
    9579
    • Saween
      Saween last edited by Saween
      Everythings is ok.
      I have in daphne\ :
      • \lair2.daphne
        lair2.commands
        lair2.txt
        lair2.m2v
        lair2.ogg
        lair2.dat
      • \roms
        lair2.zip
      In my lair2.commands, there are just X & Y..
      I don't know what can I do ๐Ÿ˜•
      Cap 1 Reply Last reply Reply Quote 0
      • Cap
        Cap @Saween last edited by
        @Saween Hmm weird. You could still try to delete lair2.commands just to rule out errors. Also, verify your rom with the MD5 sum from above.
        I had one more issue where Daphne games won't start at all. After connecting a new controller for the first time, I did not configure it. It was plugged in via USB, detected automatically and everything just worked, so I thought I was fine. But daphne/hypseus did not start because the Hotkey button was not mapped. After running the Controller Configuration and mapping the Hotkey button, it actually worked.
        • Saween
          I removed lair2.commands and I still have the same issue.
          I tried every roms:
          md5sum dl2_211.zip
          5a04b043f86fbc20e935a05c5f4465b6 dl2_211.zip
          md5sum dl2_300.zip
          7c8c27d1a6fbde8989ed6a164c7347a1 dl2_300.zip
          md5sum dl2_314.zip
          28efd77a25433b584efa7519b4d6634b dl2_314.zip
          md5sum dl2_315.zip
          fbd2ced500e578e7a65930a01d1ab70f dl2_315.zip
          md5sum dl2_316_euro.zip
          5b6fa03f5ceb01f07fe8f474cd090821 dl2_316_euro.zip
          md5sum dl2_319_euro.zip
          0006baaa494dc596f6ec00a86bc72ef8 dl2_319_euro.zip
          md5sum lair2.zip
          0006baaa494dc596f6ec00a86bc72ef8 lair2.zip
          But I don't have the same MD5..
          Maybe you can share your ".commands" & your rom to test if it's works with my setup ?
          • Cap
            @Saween Ah yeah, I think there might be an issue with your rom. The only one that is used is lair2.zip (unless you rename your game folder) and for me its MD5 is 0c2736f0e6a024ad111fe6c5150f38a4. Actually, more important is what's inside the zip, which should be this one file:
            dl2_319.bin 6d762087a3d6b2cb098a46d53e2f4995
            I don't think this forum is intended to share roms, but if you google for "dragons lair 2 rom files" you should be fine (first hit should give you one with matching MD5). ๐Ÿ˜‰
            My lair2.commands for reference:
            -nocrc -noissues -nolog -prefer_samples
            Note that especially the first three arguments are not helpful for finding errors. ๐Ÿ˜›
            Saween 1 Reply Last reply Reply Quote 0
            • Saween
              Indeed I renamed the last because i tried to use it.
              Okey I will create a new lair2.commands with the same parameters than yours. And try to found the same rom than yours.
              • sroach
                sroach @Cap last edited by
                @Cap what do you use or how do you check if the -noserversend command is being past to kick off the game?
                Interesting that lair works and lair 2 doesn't.
                I'll check Space Ace, but I don't remember any of my sound being off
                • Cap
                  Cap @sroach last edited by
                  @sroach The -noserversend argument is only used if it's included in your game's custom commands file. So I just removed it from those that don't start otherwise. E.g. for lair2, with my current commands file from above, the launcher invokes
                  # ps aux | grep hypseus
                  root 1186 11.8 1.7 65544 27196 ? Sl 15:23 0:02 /usr/bin/hypseus lair2 vldp -framefile /recalbox/share/roms/daphne/lair2.daphne/lair2.txt -fullscreen -useoverlaysb 2 -datadir /usr/share/daphne -homedir /recalbox/share/roms/daphne -nocrc -noissues -nolog -prefer_samples
                  The sound issue in Space Ace is very prominent in the scene where you fly with your ship for the first time, when Kimberly shouts "Get me out of here!!!". The video is clearly way too late. It seems to get worse the longer a scene goes on. Sometimes the sound also stops before the scene is actually over.
                  I also noted this with Dragon's Lair 1 and the dle21 rom. When Dirk breaks through the drawbridge in the very beginning, you can hear the sound before you actually see him breaking through.
                  • Saween
                    Saween @Cap last edited by
                    @Cap said in Dragon's Lair > MAME / Daphne:
                    When I write "dragons lair 2 rom files", I have the remastered version and I don't know if it's possible to put it in Recalbox..
                    • Saween
                      It's fine, I found another way to play to DL2. Thank you ๐Ÿ™‚
                      100.6k
                      Copyright ยฉ 2021 recalbox.com
