    Goldeneye N64 control problem
    GamePad/GPIO/USB encoder
    goldeneye control
    • jorgemagana
      jorgemagana last edited by
      Hello, I have a Pi4 using 7.0.1, also a PS3 style gamepad. Default Mupen emulator.
      On Goldeneye when I move forward or backward with the left analog, the camera moves up and down at the same time, so you end up staring at your feet when you walk forward.
      Seems to have same effect using pad or analog. i I remember that with 6.1.1 pad and analog worked fine with this game.
      rollbrett 1 Reply Last reply Reply Quote 0
      • rollbrett
        rollbrett @jorgemagana last edited by
        @jorgemagana You have to change in the RetroArch settings (Hotkey + X) the Analog to Digital Setting.
        SUPERPi CASE-J (new) RPi 3b+ Recalbox
        MEGAPi CASE RPi 3b Blast16
        NESPi 4 CASE RPi 4 Recalbox
        GPi CASE RPi Zero 2 W Recalbox
        My RetroArchivments
        jorgemagana Pitch64 2 Replies Last reply Reply Quote 0
        • jorgemagana
          jorgemagana @rollbrett last edited by
          @rollbrett i will try it, thanks
          • Pitch64
            Pitch64 Staff @rollbrett last edited by
            @rollbrett Thank you for this tip, I had the same issue on Perfect Dark 🙂
            Next release? Soonâ„¢
            • jorgemagana
              I found another solution: inside each game, reconfigure controls, in both 007 select the 1.2 layout, Peferct Dark select number 3 layout.
