    No Ethernet Connection x64 Intel Nuc
    ethernet connection x64 intel nuc
    • LuckyLancer
      LuckyLancer last edited by
      Hi there,
      i have a fresh install Recalbox 7.0.1 on my Intel Nuc10i5NFK (i5-10210U)
      Everything works, but my Ethernet Connection is not working. Cable is checked, with a bootable Linux the Connection is established.
      Maybe the driver for the build in NIC is missing?
      This is a "Intel Ethernet Connection I219-V"
      Can anyone help me?
      Thx!
      LuckyLance
        Hello
        changelog v7.0.2 :
        https://gitlab.com/recalbox/recalbox/-/blob/master/RELEASE-NOTES.md
        Fixe : Fix broken WIFI on some Intel chips
        May be, it's missing.
        • LuckyLancer
          Hmm. Okay thx. Maybe the Driver is comming with the Update. But how can I Update without Internet... 🙈
          I guess I need a new fresh install... Again 😅
          • LuckyLancer
            Update:
            my colleague with good Linux knowledge has take a look today.
            Prolem found for LAN-Connection:
            My NIC's driver ( l219-V) is part of the "e1000e", but the driver witch is included in Recalbox 7 is far to old. It's from 2017...
            So, the driver must be updatet in the Kernel.
            May a Developer can do this? Where can a publish this Bug?
            For WiFi, the solution is simpler. The lib-Firmwares are to old. The driver itselft is alright.
            So we have updatet the firmware in my installation and the onboard-chip works great.
            May this is relevant for the Dev's too...
            Do they read this Forum or where can I report this?
            Thanks!
              Create issue on gitlab with explanaition.
              https://gitlab.com/recalbox/recalbox/-/issues
