    Solved Anyexternal SSD Nespi 4
    anyexternal ssd nespi
    • RetroWilly
      RetroWilly last edited by
      Hello,
      Been away for awhile, and was really happy Recalbox came available on the Pi4. Bought a Nespi 4 case, so I can use an SSD.
      Here is the thing.
      In options which storage to use I selected anyexternal, in my experience with Recalbox this is any external storage i presume. However when i check this option it still shows my SD card status, and it looks like it also filled my SD card with roms. (32GB -16gb used, 62%) My SSD is 120GB..
      Did I do something wrong here?
      Hello :)
        Zing Global moderator Translator @RetroWilly last edited by
        @RetroWilly The correct is to select the name of your storage device, but anyexternal should work.
        But, read this, it might help:
        https://forum.recalbox.com/topic/21903/recalbox-7-0-1-nespi-4-recalbox-freezes-when-using-the-ssd
        RetroWilly 1 Reply Last reply Reply Quote 0
        • RetroWilly
          RetroWilly @Zing last edited by
          @Zing said in Anyexternal SSD Nespi 4:
          Thanks for replying. I figured the USB port switch out myself after my USB ports on the case were not responding very well. Switching from USB3 to USB2 did that trick. Also does my system just doesn't see the SSD, very strange.
          Did a fresh install, and now my led on my NesPi is also not working anymore.
          Hello :)
          • RetroWilly
            Solved.
            New SSD placed and formatted. Works now.
            Hello :)
            • Recalboxer
              Recalboxer last edited by
              @RetroWilly I ordered the case and I now see that people is having problems with it , can you please explain to me what do you mean by switching USB ports ?
